PROJECT: Building a grapple bucket for the LS
   / PROJECT: Building a grapple bucket for the LS #1
TSO
Elite Member
SouthEast Michigan
Massey 1652 HST Cab
Been wanting a grapple for awhile, but ended up spending the money on other things :mad: ... oh well. So, recently, I found this new 60" Rock bucket on a local auction site, and won it for $228. :thumbsup: I figured I'd either sell it for a profit OR make a grapple out of it. Well, I wen't with option 2, so here's the project so far:
The bucket:
The metal: I picked up all the metal needed for less than $100 from my local metal shop (using scraps & cut-off's like always :D ) The lid/tines are 3/8" thickness steel X 5" width. I cut them to shape and welded them into the proper angle. Added some biting-teeth to them as well.
The lid is attached to the bucket with two 3/4" bolts at the pivots. The top of that bucket is 3" tube steel, so it's a good strong base to mount things, although I used some 3"x3" angle iron as the pivot mounts. The lid opens to around 36".
This is the progress so far, but it's only been a couple days so it's moving pretty quickly I suppose. Next step is to fab up the cylinder mounts, and add some more bracing & a center half-tooth to the lid.
QUESTION for the guys that have already used their hydraulic remotes, as I haven't looked at mine yet: What size & style connectors did you use to connect to the factory remotes? How much hose is needed to run up to the front from the rear remotes?
   / PROJECT: Building a grapple bucket for the LS #2
That was a great purchace, adding a grapple will be very handy, I wish, I had one.
Dave
   / PROJECT: Building a grapple bucket for the LS #3
I wish I had one, too. The rock bucket gave you a good platform to hang the lid on,
   / PROJECT: Building a grapple bucket for the LS #4
I have been using the 'standard' connector available from TSC for my implements.
At the front for my Third Function connections, I used the same size as what the loader uses from the factory. (Where you take it off)
Hope this helps...
   / PROJECT: Building a grapple bucket for the LS #5
Local auction site? I could use a rock bucket at that price!
   / PROJECT: Building a grapple bucket for the LS #6
1/2 inch Pioneer Ag connectors
Well fellas last night I ordered a cylinder, it's 2.5" bore, 8" stroke, non ASAE, 2500psi, straight column load rating around 12500lbs. Should do the trick, now it just needs to get here. Luckily I have all the dimensions needed for the pin spacing so I should b able to fab up everything before it gets here.
QUESTION: is 3/8" hydraulic line Ok? They have 4000psi line in long lengths at my local store.
More progress:
   / PROJECT: Building a grapple bucket for the LS #9
Should be plenty. Pretty sure thats all mine has on it, and its almost too fast as it is!
   / PROJECT: Building a grapple bucket for the LS #10
Looks good, it might be a good idea to plate the joint on the sides with a dimond or triangle plate. This area will take alot of stress.
Dave
2016 Ram 4500 Chassis Ambulance (A59230)
2016 Ram 4500...
2012 VOLVO A40F OFF ROAD DUMP TRUCK (A60429)
2012 VOLVO A40F...
2023 Bobcat T770 (A60462)
2023 Bobcat T770...
2005 Cheverolet 2500 Pick Up Truck (A59814)
2005 Cheverolet...
New Holland 650 Hay Baler (A53317)
New Holland 650...
2021 KENWORTH T680 TANDEM AXLE SLEEPER (A59575)
2021 KENWORTH T680...
