3-Point Hitch Top and tilt
/ Top and tilt #1
blake037374
Baton Rouge, LA
CT440
Any body have any suggestions for top and tilt kits? I have a bobcat ct440 I checked bobcat dealer for rear remote setup but it puts the handles next to my right leg and don't really like that by my leg. I saw someone that mounted valve for it next to seat
/ Top and tilt #2
I believe that those control levers can be modified to get them away from being so close to your leg, and that is what I would do. As far as the actual "T&T" set, (cylinders, hoses, QDs, flow restrictors) you would be looking at $635 + shipping if you get them from me. If you want to go after market valves, I can set you up with a 2 spool set for $755, but recommend the 3 spool for $890.
Email me if you are interested. ;)
/ Top and tilt #4
You have pictures of your control valves?
These are what I sell. Made in Germany. The guy that installed that loader valve on the right side of his seat next to the fender has been having some problems with the valve.:( To bad too, he did a GREAT installation of that whole setup. :thumbsup:
/ Top and tilt
I see most with box blade. I'm assuming you can still bushhog with it
/ Top and tilt #7
What problems was he having?
Major internal leakage and it was starting to look like it was at a rate of what the manufacturer was saying was acceptable. :eek: So the hydraulic cylinders were dropping at a rate that was really unacceptable to be properly used. :(
Yes, all normal 3pt work should be able to be performed.
(INOP) 1994 CHEVROLET 1500 TRUCK TRUCK (A63291)
(INOP) 1994...
2017 CATERPILLAR 950GC WHEEL LOADER (A64279)
2017 CATERPILLAR...
2014 Chevrolet Impala Sedan (A61574)
2014 Chevrolet...
MASSEY FERGUSON 4 BOTTOM PLOW (A63291)
MASSEY FERGUSON 4...
2023 Nissan Altima Sedan (A61574)
2023 Nissan Altima...
2019 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2019 INTERNATIONAL...
