How do you fuel your tractor (logistics, not finding the cap to the tank)?
   / How do you fuel your tractor (logistics, not finding the cap to the tank)? #91
No more fuel than I go through on the weekends I use a 5 gal can and a battery fuel pump from Lowes for filling Kerosene Heaters for mine. Works great and I don't end up making a mess, plus I have 3 of those new cans that the fuel won't pour out of, and it comes out fine with this little pump. Best of all it only uses 2 D batteries, about one set a year!
Just looked up the pump you're talking about, very nifty. How long have you had it?
   / How do you fuel your tractor (logistics, not finding the cap to the tank)? #92
I am on my second one but I think I got almost 2 years out of the first one The batteries last forever with no bigger than the pump is.
   / How do you fuel your tractor (logistics, not finding the cap to the tank)? #93
I can't find it on Lowe's site. Do you have a link?
   / How do you fuel your tractor (logistics, not finding the cap to the tank)? #96
I've never actually tried this, but what about getting a high end fuel pump, like the kind race cars use. Curently I have to deal with gas not diesel. It seem like a switch and some hose you could rig up a pump and pump from the ground into the tank. Just a thought.
Wedge
   / How do you fuel your tractor (logistics, not finding the cap to the tank)? #97
Will the Duraheat siphon move hydraulic fluid, or is it too thick/heavy?
   / How do you fuel your tractor (logistics, not finding the cap to the tank)? #98
Good question! My thoughts on that are that as long as it would work at least long enough to move enough fluid for a fluid change, $15 isn't a bad price for a one use tool to make the job a bit easier. In my case I couldn't find a drain pan to collect all ten gallons of fluid so I had to put the drain plug in and empty my pan a couple times. I could use that to suck the old fluid from the pan into disposal containers as it drains. It would also make moving fluid from the 5 gallon containers into the reservoir easier as well, but with a little creativity I did ok with that. I have a while before I need to do it again, thank goodness only the first is at 50 hours.
   / How do you fuel your tractor (logistics, not finding the cap to the tank)? #99
Well the guys beat me to the link, I use the one outside for gas and have not had any problems with that. I don't think it will handle hydraulic fluid but I could be wrong, it may but for how long I don't know, the impeller is only plastic.
   / How do you fuel your tractor (logistics, not finding the cap to the tank)? #100
10 gallons would be good enough for me. You use that battery-electric kero pump for gasoline? I hope I'm wrong to feel concerned about that. I thought lots of the small electric pumps were OK for diesel and kero but not gas due to the fume flammability?
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
2006 Utility Trailer MFD. T/A 32FT Dry Van Trailer (A56858)
2006 Utility...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Set of 4 12-16.5 Bobcat Wheels and Tires (A56857)
Set of 4 12-16.5...
1993 UTILITY TRAILER MANUFACTURER 45 FLATBED T/A TRAILER (A58214)
1993 UTILITY...
3 Row Twin Row Renaldo Planter (A53317)
3 Row Twin Row...
