How do you fuel your tractor (logistics, not finding the cap to the tank)?
   / How do you fuel your tractor (logistics, not finding the cap to the tank)? #91
No more fuel than I go through on the weekends I use a 5 gal can and a battery fuel pump from Lowes for filling Kerosene Heaters for mine. Works great and I don't end up making a mess, plus I have 3 of those new cans that the fuel won't pour out of, and it comes out fine with this little pump. Best of all it only uses 2 D batteries, about one set a year!
Just looked up the pump you're talking about, very nifty. How long have you had it?
   / How do you fuel your tractor (logistics, not finding the cap to the tank)? #92
I am on my second one but I think I got almost 2 years out of the first one The batteries last forever with no bigger than the pump is.
   / How do you fuel your tractor (logistics, not finding the cap to the tank)? #93
I can't find it on Lowe's site. Do you have a link?
   / How do you fuel your tractor (logistics, not finding the cap to the tank)? #96
I've never actually tried this, but what about getting a high end fuel pump, like the kind race cars use. Curently I have to deal with gas not diesel. It seem like a switch and some hose you could rig up a pump and pump from the ground into the tank. Just a thought.
Wedge
   / How do you fuel your tractor (logistics, not finding the cap to the tank)? #97
Will the Duraheat siphon move hydraulic fluid, or is it too thick/heavy?
   / How do you fuel your tractor (logistics, not finding the cap to the tank)? #98
Good question! My thoughts on that are that as long as it would work at least long enough to move enough fluid for a fluid change, $15 isn't a bad price for a one use tool to make the job a bit easier. In my case I couldn't find a drain pan to collect all ten gallons of fluid so I had to put the drain plug in and empty my pan a couple times. I could use that to suck the old fluid from the pan into disposal containers as it drains. It would also make moving fluid from the 5 gallon containers into the reservoir easier as well, but with a little creativity I did ok with that. I have a while before I need to do it again, thank goodness only the first is at 50 hours.
   / How do you fuel your tractor (logistics, not finding the cap to the tank)? #99
Well the guys beat me to the link, I use the one outside for gas and have not had any problems with that. I don't think it will handle hydraulic fluid but I could be wrong, it may but for how long I don't know, the impeller is only plastic.
   / How do you fuel your tractor (logistics, not finding the cap to the tank)? #100
10 gallons would be good enough for me. You use that battery-electric kero pump for gasoline? I hope I'm wrong to feel concerned about that. I thought lots of the small electric pumps were OK for diesel and kero but not gas due to the fume flammability?
Year: 2016 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55853)
Year: 2016 Make...
5' SCRAPE BLADE, 3PT (A52708)
5' SCRAPE BLADE...
IRON FORCE IMPACT SET (A58374)
IRON FORCE IMPACT...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2018 Ford F-150...
D.M. 207 - 7 BLADE DISC MOWER (A52708)
D.M. 207 - 7 BLADE...
JOHN DEERE 624K WHEEL LOADER (A58214)
JOHN DEERE 624K...
