Grading A Road With Water Bars
   / Grading A Road With Water Bars #11
Start at the top of the hill and work down, building as you go. A box blade works pretty good for making them. Open top culverts work better and are easier to maintain but are much more labor intensive to build.
Thanks for all the great replies! That video contains some good info too! I do have mostly rolling dips, but had to use water bars in some of the steeper areas where we didn't have enough room to put in the dips. I have a feeling at a minimum, a TNT and grader is going to be on my priority list, although it sure would be nice to have one of those road graders :) Anyone using one of the Roadrunner Graders? They are about twice as heavy as the LP GS2584, and about 10% more expensive.
My first thought is for a rear blade with gauge wheel(s), and easy it over the bars without cutting. Never used one, though.
Center wheel(s) on frame:
or two wheels on the blade:
The Bush Hog blade parts manual shows several "tailwheels" that could be copied or bought.
http://www.bushhog.com/images/stories/documents/manuals/rearmtdbladesparts.pdf
Bruce
Thanks for the link Bruce - I'll check pricing on those Hydraulics from BH. That sure would save me some time getting on and off the tractor to adjust the blade angle
   / Grading A Road With Water Bars #14
Yes they are heavier than the Land Pride units. But if you look at a few others you will find several heavy units that are available.
GradeMaster Grader Blades
Home | Road Boss Grader I know that these typically run about 200lbs per foot width.
Thanks for the addl. links Brian. I will be in touch with you soon on a TNT kit, as soon as I figure out what I will need.
   / Grading A Road With Water Bars #16
   / Grading A Road With Water Bars #17
Those water bars you mention are called Kelly bumps around here by the old timers. I think I would be looking at used road graders to maintain that much road..
   / Grading A Road With Water Bars #18
Hmmmm - learned something today, water bars. My first though was a road grader also; especially when the OP indicated "many miles of road" & "didn't want to spend any more time than he had to on road maintenance". Its going to be difficult to maintain many miles of road with a utility tractor and any kind of implement(s) and not spend a lot of time on maintenance. I have a mile long driveway and I sure get A LOT of seat time doing maintenance. And by the very nature of the beast - roads in the mountains are going to require more maintenance.
   / Grading A Road With Water Bars #19
I just sold a top link to the Good Year Proving grounds in Texas to use on their JD 7810. (Big tractor, 180hp I think). Anyway, they have 25 miles of roads that they maintain on 7000 acres. The guy says that the tractor runs 8 hours a day, 5 days a week. They use a Road Boss to do all of the light maintenance and have 3 motor graders that get used for things that get seriously messed up.
KODIAK 10' HD ROTARY MOWER (A51406)
KODIAK 10' HD...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A50397)
2024 BCL...
2018 Toro Groundsmaster 7200 72in Zero Turn Mower (A48082)
2018 Toro...
2014 VOLVO VNM DAY CAB (A51222)
2014 VOLVO VNM DAY...
INGERSOLL RAND COMPRESSOR (A50854)
INGERSOLL RAND...
2015 FORD F-150 (A50854)
2015 FORD F-150...
