Help me put together the ULTIMATE aux hyrdaulic setup.
/ Help me put together the ULTIMATE aux hyrdaulic setup. #21
Aside from cost, I can't think of any. I really don't even think cost difference is that much.
Although, now I am confused... are you wanting to get solenoid valves, or manual valves?
/ Help me put together the ULTIMATE aux hyrdaulic setup. #22
So is there any disadvantage to getting all of my valves (except the motor) with float?
ac
No, get the valves with the float function and the lone motor spool valve.
You may want to take a look at some other manufacturers valves before you purchase. ;)
Do the valves with float have closed centers so the pistons stay in position when the valve is in neutral?
Any suggestions about what else to look at? I just found these at Grainger in a manner I could finally understand, that is how I stumbled on the Prince.
ac
/ Help me put together the ULTIMATE aux hyrdaulic setup. #24
ac
You can take a look here. You can buy direct or from me and save a few dollars. These Bucher valves are made in Germany, and as of this date, I have had zero complaints about them. A little more compact than the Prince valves and the control lever has a different design to them. Email me and I would be happy to get you a quote for whatever combination of valves that you are considering. I can provide the FEL setup also if you want. ;)
Yes the hydraulics stay in place with the valve in neutral.
Email sent.
ac
/ Help me put together the ULTIMATE aux hyrdaulic setup. #26
those do look like nice valves, but are those the work ports on the top there? I don't know that I would like that.
/ Help me put together the ULTIMATE aux hyrdaulic setup. #27
No, but there is no reason for a third float. Two float valves for T-N-T.
Maybe one motor spool valve for auger unless you will have a valve at the auger, then you can use the three position detent.
You might consider a three position detent for say a log splitter, hyd stump grinder.
/ Help me put together the ULTIMATE aux hyrdaulic setup. #28
Can you please show me a spool valve that has them some place else. Not familiar with any. :confused:
/ Help me put together the ULTIMATE aux hyrdaulic setup. #29
I'm not sure they exist, I am used to the solenoid actuated valves at my work and have seen them on all sides.
/ Help me put together the ULTIMATE aux hyrdaulic setup. #30
There is no reason that you can not turn any of the valves upside down.
Just have to remember where the float is.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Sdlanch 20'x20' High End Carport (A60463)
Sdlanch 20'x20'...
2025 Pabreak Hydraulic Brush Cutter Skid Steer Attachment (A61567)
2025 Pabreak...
iDrive TDS-2010H...
SCAN TO RECEIVE TEXT UPDATES (A62129)
SCAN TO RECEIVE...
1992 Talbert 70 Ton Lowboy Trailer with Removable Gooseneck (A61307)
1992 Talbert 70...
