GM unveils new 6.2 1/2t specs
   / GM unveils new 6.2 1/2t specs #2
Nice. I keep hearing rumors the Ford EcoBoost is due for a power increase of about 40hp and 40 ft tq. If they are on par with one another it would be interesting to see them head to head.
This also makes the diesel offerings look less attractive unless they can pull in a low 30mpg average.
Chris
Crazy the power that trucks make these days.
   / GM unveils new 6.2 1/2t specs #4
Good numbers just wish they could do it without feeding it 91 octane. I too am anxious to see some real world comparisons with the ecoboost. Looks like we might have a new winner if they have a decent torque curve.
   / GM unveils new 6.2 1/2t specs #5
New 6.2L Makes GM Trucks Most Powerful Light Duties
Impressive! Be nice to see the fuel economy numbers.
The MPG's would be a curiosity but given that I average 15-16 with my '13 6.2, 2-3 mpg would be welcome...I thought I wanted a Dmax until I used my new one to pull our new 32' TT and I can say I don't...This thing pulls like a beast (for some reason better than my 2011 6.2) and on non-premium gas with 3:42's and a 6 speed in both...These things get better every year..
   / GM unveils new 6.2 1/2t specs #6
Ford has been making close to those numbers for a couple years on regular gas.
   / GM unveils new 6.2 1/2t specs #7
SPECIFICATIONS - SIERRA 1500 CREW CAB
Engines EcoTec3 4.3L V6 FlexFuel
(LV3) EcoTec3 5.3L V8 FlexFuel
(L83) EcoTec3 6.2L V8 FlexFuel
(L86)
Type: 4.3L V6 5.3L V8 6.2L V8
Displacement (cc / cu in): 4300 / 262 5328 / 325 6162 / 376
Bore & stroke (mm / in): 99.6 x 92 / 3.92 x 3.62 96 x 92 / 3.78 x 3.62 103.25 x 92 / 4.06 x 3.62
Block material: Cast aluminum Cast aluminum Cast aluminum
Cylinder head material: Cast aluminum Cast aluminum Cast aluminum
Valvetrain: Overhead valve, two valves per cylinder, variable valve timing Overhead valve, two valves per cylinder, variable valve timing Overhead valve, two valves per cylinder, variable valve timing
Ignition system: Coil near plug, platinum-tipped spark plugs, low-resistance spark plug wires Coil near plug, platinum-tipped spark plugs, low-resistance spark plug wires Coil near plug, platinum-tipped spark plugs, low-resistance spark plug wires
Fuel delivery: Direct fuel injection with Active Fuel Management Direct fuel injection with Active Fuel Management Direct fuel injection with Active Fuel Management
Compression ratio: 11.0:1 11.0:1 11.5:1
Horsepower (hp / kW @ rpm): 285 / 212 @ 5300 (gas)
297 / 221 @ 5300 (E85) 355 / 250 @ 5600 (gas)
380 / 283 @ 5600 (E85) 420 / 313 @ 5600 (est.)
Torque (lb-ft / Nm @ rpm): 305 / 413 @ 3900 (gas)
330 / 447 @ 3900 (E85) 383 / 519 @ 4100 (gas)
416 / 564 @ 4100 (E85) 450 / 610 @ 4100 (est.)
Recommended fuel: Regular unleaded or E85 Regular unleaded or E85 Regular unleaded or E85
Maximum engine speed (rpm): 5800 5800 6000
Emissions controls: Close-coupled catalytic converter, Quick Sync 58X ignition, returnless fuel rail, fast-response O² sensor Close-coupled catalytic converter, Quick Sync 58X ignition, returnless fuel rail, fast-response O² sensor Close-coupled catalytic converter, Quick Sync 58X ignition, returnless fuel rail, fast-response O² sensor
Estimated fuel consumption:
Mi/imp.gal (city / hwy / combined) 2WD: TBD
4x4: TBD 2WD: 22 / 32 / 26
4x4: 21 / 31 / 25 2WD: TBD
4x4: TBD
L/100km (city / hwy / combined) 2WD: TBD
4x4: TBD 2WD: 13.0 / 8.7 / 11.0
4x4: 13.3 / 9.0 / 11.4 2WD: TBD
4x4: TBD
   / GM unveils new 6.2 1/2t specs #8
Holy cow 11.5 compression on the 6.2, that is why it needs premium gas.
The Ford 6.2 is 9.8 IIRC.
   / GM unveils new 6.2 1/2t specs #9
This is the first time that the Chevy's look better than the GMC's IMHO...Those stupid headlights look like they have a black eye on the GMC version...Looked at a '14 when I bought my '13 and couldn't digest the front end...See a ton of them on the road now and really like the '14Chevy until I get used to the GMC....That whole new thing with the LED's doesn't do anything for me..They look like blingy Christmas lights...Not necessary..Thanks Audi who seems to have started this stupid craze. Plus the money falling out of trees pushed me to the '13.
GM did some really cool stuff with the '14 trucks, my objections not withstanding...Under-rail lighting in the bed, power and USB ports EVERYWHERE, interior storage out the wazoo, huge touch screen with camera, very roomy interior, flat rear floors, absurdly quiet interior, very responsive engines (only got to test a 5.3), controls in places that are really intuitive, comfortable seating, and multiple bed/cab configurations and on and on...
I tend to wait until new versions ferment for a while before my buying curiosity peaks although GM seems to have dealt with that everlasting gremlin based on the various GM buyers I work with..Virtually no problems beyond stupid stuff.
UNUSED AGT SKID STEER QUICK ATTACH PALLET FORKS (A51244)
UNUSED AGT SKID...
2010 CATERPILLAR CM1210106 ROUGHT TERRAIN FORKLIFT (A51242)
2010 CATERPILLAR...
2014 Volkswagen Jetta Sedan (A50324)
2014 Volkswagen...
Set of Tractor Tracks (A50514)
Set of Tractor...
2010 Triple B Gooseneck Inclosed Car Trailer (A50514)
2010 Triple B...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
