SPECIFICATIONS - SIERRA 1500 CREW CAB
Engines EcoTec3 4.3L V6 FlexFuel
(LV3) EcoTec3 5.3L V8 FlexFuel
(L83) EcoTec3 6.2L V8 FlexFuel
(L86)
Type: 4.3L V6 5.3L V8 6.2L V8
Displacement (cc / cu in): 4300 / 262 5328 / 325 6162 / 376
Bore & stroke (mm / in): 99.6 x 92 / 3.92 x 3.62 96 x 92 / 3.78 x 3.62 103.25 x 92 / 4.06 x 3.62
Block material: Cast aluminum Cast aluminum Cast aluminum
Cylinder head material: Cast aluminum Cast aluminum Cast aluminum
Valvetrain: Overhead valve, two valves per cylinder, variable valve timing Overhead valve, two valves per cylinder, variable valve timing Overhead valve, two valves per cylinder, variable valve timing
Ignition system: Coil near plug, platinum-tipped spark plugs, low-resistance spark plug wires Coil near plug, platinum-tipped spark plugs, low-resistance spark plug wires Coil near plug, platinum-tipped spark plugs, low-resistance spark plug wires
Fuel delivery: Direct fuel injection with Active Fuel Management Direct fuel injection with Active Fuel Management Direct fuel injection with Active Fuel Management
Compression ratio: 11.0:1 11.0:1 11.5:1
Horsepower (hp / kW @ rpm): 285 / 212 @ 5300 (gas)
297 / 221 @ 5300 (E85) 355 / 250 @ 5600 (gas)
380 / 283 @ 5600 (E85) 420 / 313 @ 5600 (est.)
Torque (lb-ft / Nm @ rpm): 305 / 413 @ 3900 (gas)
330 / 447 @ 3900 (E85) 383 / 519 @ 4100 (gas)
416 / 564 @ 4100 (E85) 450 / 610 @ 4100 (est.)
Recommended fuel: Regular unleaded or E85 Regular unleaded or E85 Regular unleaded or E85
Maximum engine speed (rpm): 5800 5800 6000
Emissions controls: Close-coupled catalytic converter, Quick Sync 58X ignition, returnless fuel rail, fast-response O² sensor Close-coupled catalytic converter, Quick Sync 58X ignition, returnless fuel rail, fast-response O² sensor Close-coupled catalytic converter, Quick Sync 58X ignition, returnless fuel rail, fast-response O² sensor
Estimated fuel consumption:
Mi/imp.gal (city / hwy / combined) 2WD: TBD
4x4: TBD 2WD: 22 / 32 / 26
4x4: 21 / 31 / 25 2WD: TBD
4x4: TBD
L/100km (city / hwy / combined) 2WD: TBD
4x4: TBD 2WD: 13.0 / 8.7 / 11.0
4x4: 13.3 / 9.0 / 11.4 2WD: TBD
4x4: TBD
