Cub Cadet 1050 electric clutch problems
   / Cub Cadet 1050 electric clutch problems #1
preacher64
Peterstown,WV
3910 Ford, 1510 Ford, Super A Farmall, Cub Cadet 1050
The electric clutch operates for a few minutes then shuts off. Test light indicates power is still going to clutch???
   / Cub Cadet 1050 electric clutch problems #2
If it has the operator present seat safety switch, and/or the mow in reverse switch, either of those two could turn the clutch off.
   / Cub Cadet 1050 electric clutch problems #3
Mine was doing that. Wound up wiring it directly to the battery with a switch. Temporarily for trouble shooting of course. Works great, which makes me think it was the relay.
It has both the reverse switch and the operator seat safety switch.
I may try that to see what takes place. thanks.
   / Cub Cadet 1050 electric clutch problems #6
Maybe one of those switches or associated wires is flakey, or the relay mentioned above. Both switches are designed to disengage the blade clutch, so it's very possible they could cause the problem.
You could try Riding Mower, Lawn Tractor, Zero Turn Mower for info, although I don't recall seeing a wiring diagram on there, I never looked for one either. Never had a problem in that area--yet.
   / Cub Cadet 1050 electric clutch problems #7
My 1050 did that. Never could figure out what was going on. Finally wound up giving the top of the deck a good cleaning--all around the pulleys and belts and such. Problem solved. Still don't know what the trouble actually was.
2005 Chevrolet Impala Sedan (A56859)
2005 Chevrolet...
2025 SDLANCH SDLE20 MINI EXCAVATOR (A58214)
2025 SDLANCH...
STAINLESS STEEL SALAD BAR (A58374)
STAINLESS STEEL...
2007 Capacity TJ6500T Wet Kit T/A Yard Dog Toter Truck (A55973)
2007 Capacity...
2020 Deere 50G (A53317)
2020 Deere 50G...
JLG 15 MVL MANLIFT (A58214)
JLG 15 MVL MANLIFT...
