Cub Cadet 1050 electric clutch problems
   / Cub Cadet 1050 electric clutch problems #1
preacher64
Peterstown,WV
3910 Ford, 1510 Ford, Super A Farmall, Cub Cadet 1050
The electric clutch operates for a few minutes then shuts off. Test light indicates power is still going to clutch???
   / Cub Cadet 1050 electric clutch problems #2
If it has the operator present seat safety switch, and/or the mow in reverse switch, either of those two could turn the clutch off.
   / Cub Cadet 1050 electric clutch problems #3
Mine was doing that. Wound up wiring it directly to the battery with a switch. Temporarily for trouble shooting of course. Works great, which makes me think it was the relay.
It has both the reverse switch and the operator seat safety switch.
I may try that to see what takes place. thanks.
   / Cub Cadet 1050 electric clutch problems #6
Maybe one of those switches or associated wires is flakey, or the relay mentioned above. Both switches are designed to disengage the blade clutch, so it's very possible they could cause the problem.
You could try Riding Mower, Lawn Tractor, Zero Turn Mower for info, although I don't recall seeing a wiring diagram on there, I never looked for one either. Never had a problem in that area--yet.
   / Cub Cadet 1050 electric clutch problems #7
My 1050 did that. Never could figure out what was going on. Finally wound up giving the top of the deck a good cleaning--all around the pulleys and belts and such. Problem solved. Still don't know what the trouble actually was.
INGERSOLL RAND G25 GENERATOR (A58214)
INGERSOLL RAND G25...
Mohawk 12,000lb Two-Post Electric Auto Lift (A55851)
Mohawk 12,000lb...
NEW Wolverine 72in Skid Steer Ripper (A59000)
NEW Wolverine 72in...
2015 Ford Transit Connect XL Cargo Van (A56858)
2015 Ford Transit...
2016 Ford F-350 Super Duty Pickup Truck, VIN: 1FT8W3DT1GEB84319, Crew Cab, 4x4, Steel Flatbed (A59076)
2016 Ford F-350...
JOHN DEERE 6000 HI-CYCLE GREEN TOP SPRAYER (A52708)
JOHN DEERE 6000...
