7730 three point hitch
/ 7730 three point hitch #1
Gab martin
Chatham on
John deere 7730
I was plowing along, got to the headland and couldn't raise the plow, I was able to get the plow up using the switches at the back one time. got it home but now it won't move in either direction. dealer said two days before they can get a look at it. Anyone know of anything common I could try. any help at all would be appreciated.
/ 7730 three point hitch #2
Does your hitch control valve have a manual override? Check your operators manual.
Might be the position sensor failed, or its wiring/connector.
Or the solenoid on the hitch control valve, or its wiring/connector.
/ 7730 three point hitch #3
Restart the tractor, Happened on my 7230R when I was plowing. I restarted the machine then everything was operational again.
Had the JD dealer come out to the farm, He re calibrated it and away it went. Plowed all day after. Strange?
2011 TORO SP5040 MOWER (A66091)
2011 TORO SP5040...
2019 GENERAC MDG75DF4 TOWABLE GENERATOR (A63276)
2019 GENERAC...
New/Unused Quick Attach Pallet Double Hay Spear (A65583)
New/Unused Quick...
2019 Ford F-150 4x4 Ext. Cab Pickup Truck (A64556)
2019 Ford F-150...
New/Unused 2 Post Car Lift (A65583)
New/Unused 2 Post...
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A64556)
2022 Peterbilt 567...
