BX 2200 filter cross reference
/ BX 2200 filter cross reference #1
millwrightdude
I just bought a BX 2200 and I want to do a complete service, does someone have cross reference for the filters? I could use oil filter, hydraulic filter,fuel filter
Thanks
Oh, Great. Thank you very much
/ BX 2200 filter cross reference #4
Oil: Wix 51064
HST: Wix 57088
Fuel: Wix 33972 (two required)
Napa sells Wix under the Napa brand. Usually taking off the front number gives the Napa number. ie: Wix 51064 = Napa 1064
/ BX 2200 filter cross reference #5
Oil: Wix 51064
HST: Wix 57088
I would be careful on the WIX 33972 as the media in the filter is listed as plastic mesh and is not the water blocking paper like the Kubota, once again the WIX cross is improper.
Get it here for $4.96
Wix 33972 for sale
Part Number: 33972
UPC Number: 765809339729
Principle Application: Plastic Universal In-line fuel filter w/ 5/16" lines - can be used w/ gasoline or diesel fuel (33002 only to be used w/ gas)
Applications
Style: Fuel (Complete In-Line) Filter
Service: Fuel
Type: Full Flow
Media: Plastic Mesh
Height: 3.636
Outer Diameter Top: 1.828
Outer Diameter Bottom: Closed:
Burst Pressure-PSI: 58
Max Flow Rate: 1 GPM
Nominal Micron Rating: 50
I guess if you feel 50 micron is proper for your injection pump then you can use it, but I value mine a little more.
David Kb7uns
What oil weight are you guys running. I see that there are 3 choices. I'm thinking 10W40
/ BX 2200 filter cross reference #8
Oil is a hot button as I have seen in a lot of post here. I use Shell Rotella T6 5-40. I'm now just short of 700hrs on my BX2200. Just my experience, the WIX fuel filter would not fit in my filter bracket so I use Kubota filters, my dealer prices are sky high with an attitude so I order over the phone now and give a pleasant dealer the sale. Best of luck with your new machine. Dan
/ BX 2200 filter cross reference #10
Although I posted the fuel filter cross-reference I use the Kubota branded ones. The OP asked for cross-references.
As far as the oil is concerned, this link was stolen from a like-subject thread here on TBN. It is a test of oils for both diesel and gas applications.
Diesel Oil
2012 Kubota RTV 1140 4x4 Diesel Utility Cart (A61567)
2012 Kubota RTV...
2006 John Deere 325 Skid Steer (A63116)
2006 John Deere...
Dexter trailer axles (A61567)
Dexter trailer...
Excavator trenching bucket- one bucket per lot (A63118)
Excavator...
2014 CATERPILLAR TL642C TELESCOPIC FORKLIFT (A62129)
2014 CATERPILLAR...
2007 JLG 600S TELESCOPIC BOOM LIFT (A62129)
2007 JLG 600S...
