Help me put together the ULTIMATE aux hyrdaulic setup.
/ Help me put together the ULTIMATE aux hyrdaulic setup. #1
avc8130
Northern, NJ
Kubota L45
I'm getting ready to make a mother-load order from surpluscenter.com for hydraulic components to outfit my Kubota L45 once and for all. I want to add the following:
3rd Function. I'm figuring I need the following:
Solenoid valve Surplus Center - 12 VDC 10 GPM OC DA SOLENOID VALVE
Subplate Surplus Center - 1 STATION DO3 SUBPLATE OPEN CENTER
Connectors Surplus Center - HIRSCHMANN CONNECTOR
Various SAE -6 to JIC -6 fittings.
Various JIC-6 hoses.
Flat face quick couplers Surplus Center - 1/2" NPT FLUSH FACE QUICK COUPLER SET ISO 16028
JIC -6 to 1/2" NPT fittings.
Dust covers for couplers.
Rear:
This is where I need help. I have no idea what I need in the rear. I figure I want 3 valves just to have. I assume I'll wind up with top n tilt eventually. Maybe a valve to allow a log splitter or other hydraulic add on? I need help/suggestions here.
Backhoe Thumb:
I'm thinking a diverter valve setup off one of the hoe functions. Surplus Center - 12 VDC 13.2 GPM SAE 8 DOUBLE SELECTOR VALVE
Appropriate SAE -8 fittings and hoses to support.
How do my plans look? I really could use advice on the rear remotes obviously.
Thanks!
ac
/ Help me put together the ULTIMATE aux hyrdaulic setup. #2
You need to rethink what tractor it is that you have there. Your pump puts out 25GPM.:cool: You are just asking for trouble with the 10GPM 3rd function setup that you are looking at. :no:
I WISH I had 25 gpm to deal with. That is a combined number for 2 separate hydraulic pumps.
I have 11.8 GPM for loader/backhoe function.
ac
/ Help me put together the ULTIMATE aux hyrdaulic setup. #4
ac
Ok, sorry for my mis reading of the specs. I did not look at the notations at the bottom of the spec sheet. :eek: I should have known better, and do actually, just in a hurry. :ashamed:
I would still be wary of the 10GPM valve though. It will heat up your oil some. ;)
Do you think that really matters on something like a grapple that is used for very short periods of time?
ac
/ Help me put together the ULTIMATE aux hyrdaulic setup. #6
I would do 4 valves in the rear, since the tnt will use 2. That way you could add a 2 axis hydraulic blade or similar. Also think hard about what you may want to use them for to dictate what kind valve you buy- a cylinder or a motor, and what kind of detents you would want- do you want spring return to center or stay in one position or the other, do you want to have a float detent? Ideally, if money (and space) was no object, you would want a dozen valves so you could have a couple each with different functions. Of course that is out of the question I would assume, but you are asking about the "ultimate" hydraulic setup.
Also, about the log splitter, I would not necessarily plan on that since I think it would be better to leave a power beyond set available and mount a valve on the splitter itself.
/ Help me put together the ULTIMATE aux hyrdaulic setup. #7
ac
Should have little effect as you probably will not be running the engine at WOT all the time.
You should consider a diverter/selector valve for the grapple using the joystick for the curl and grapple. This will also let you feather the grapple where as the 3rd function is full flow all the time.
This is why I need the help!
I see most tractors are offered with 3-valve aux. What are those typically?
Right now I have NO hydraulic accessories for the rear. This is just future proofing.
I assume a valve with "float" would be good for the "Top".
A "normal" valve would be good for the "Tilt"? This should probably be spring-center?
ac
/ Help me put together the ULTIMATE aux hyrdaulic setup. #9
ac
As a diverter it would make no difference, but you will have fluid flowing through that true 3rd function 100% of the time. I would use whatever size the OEM line is. There is a reason for that size, and that reason is so the fluid doesn't heat up and you have full unrestricted flow when you need it. Do as you will, you are the one that has to deal with the out come. There is a good chance that all will be fine. Or you can spend a few $$$ more and know that all will be fine, no matter what. Just get a different valve, sub plate & fittings and use 1/2" hose and all will be good, no mater what your conditions might be.
Just my :2cents:
/ Help me put together the ULTIMATE aux hyrdaulic setup. #10
In another post, MtnViewRanch posted a picture of three diverter valves that would let you use a single valve to operate three cyl.
If the remote valve had float, each of the three circuits would have float.
You would connect the three diverter valves in series with the work ports of the single valve and have 4 sets of QD.
Select say circuit #1 solenoid, and then the remote valve would provide DA operation to the valve plus float.
The first diverter valve in series has priority.
You could also do the 3rd function package using a solenoid valve and subplate to provide 4 sets of QD's.
The 3rd function valves would be in series with the PB out of the remote valve.
These valves will provide full flow with no feathering.
Just my :2cents:
No need to get snippy. I think I just realized your point: the fluid is ALWAYS flowing through the PB portion of the 3rd function valve. So whether I am "using" it or not, it is reducing the flow.
Correct?
Remember, I started this thread because I have a lot to learn about this stuff and there is no FAQ I could find.
ac
I'm starting to learn and I think I have figured out some things:
I am looking at Prince SV series valves since they appear to be Made in USA and of good quality for reasonable prices.
I've come up with the following:
SVW1CA1: 4-Way Motor Spool w/ Spring Center (Work Ports Open to Tank in Neutral) This looks like it would be good for a hydraulic motor such as an auger.
SVW1BA1: 4-Way Double Acting w/ Spring Center (Work Ports Blocked in Neutral) This looks like it would be good for a double-acting cylinder that I want to STAY in position.
SVW1DD1: 4-Way 4 Position Float w/ Spring Center and Float Detent This looks like it would be good to be able to "float" a double-acting cylinder.
What would SVW1AA 3-Way Single Acting w/ Spring Center be good for?
Other than cost, is there any reason NOT to use 2 SVW1DD1?
Thanks,
ac
/ Help me put together the ULTIMATE aux hyrdaulic setup. #13
Correct?
ac
Correct, there is constant flow with that type of valve. That sub plate uses #6 fittings, those and the passages in the valve are just to small for the constant flow for your tractor. Best to spend a few more dollars and not have to be concerned if you will be doing any damage to the system IMO. ;)
/ Help me put together the ULTIMATE aux hyrdaulic setup. #14
Thanks,
ac
I would not use the single action stack, because you can use a DA splool for a SA cyl by using B work port and plug the other or run the A port to tank.
Probably should have two SVW1DD1 valves with float one for TTL tractor top link and other for the tilt.
The three way detent valve will also run an auger, but use a motor spool if you want to.
I say this again. If you do not run your tractor at WOT, you probably are not producing more than 10 GPM's, so you should be safe.
You can use larger valves and hose if you want to, but not necessary in your situation. You biggest heat source is a relief valve, relieving over pressure.
You can always add to a stacked valve or replace each stack.
These valves are rated for 12 gpm, so I should be good there, right?
You are saying I could use SVW1BA to run a motor? But wouldn't stopping the motor put a strain on the system, rather than a true motor valve allowing the motor to "spin down"?
ac
/ Help me put together the ULTIMATE aux hyrdaulic setup. #16
That is true if you had a large centrifugal force like a bush hog.
The trick is letting the lever return slowly. Also, a double relief valve across a hyd motor will also protect the motor and valve.
An auger only turns at 150 to 300 max.
You should be good with the 12 GPM rating.
/ Help me put together the ULTIMATE aux hyrdaulic setup. #17
On your question about using all float valves on SV - generally your assumption is true, you don't HAVE to use the float position but it's nice to have it IF you want to.
One downside, that may or may not affect you - be aware that the standard handles that ship with SV valve sections have a "dogleg" in them - they are bent just above where the two holes are drilled in the handle, one hole for the pivot point and the other to pin to the valve spool itself.
The Handles end up kind of close together for use with gloves - you can reverse every other handle (not the valve section, just the handle) so one is offset AWAY from you, the next one TOWARD you - this gives you a "feel" method of finding the right handle without looking at it, and gives you more "glove room"...
BUT - I found out by trial and error that, if you put TWO FLOAT sections next to each other and mount your handles with one bent forward, the other bent backward, the valve with the handle bent TOWARD the spool will NOT make it all the way into float position before the bend in the handle stops spool movement.
I have an SV with two float, plus two spring center sections - my (marginal) solution is to alternate Float and non-float sections, point the handles AWAY from spool on the float sections and TOWARD the spools on the other two sections.
This gives me "glove room" between handles by having the "shift balls" staggered, but means that I can not have two "float functions" adjacent to each other on the stack UNLESS I'm willing to fight the close spacing.
If you have smaller hands than mine, or don't consider this a problem, cool - just sharing an UN-DOCUMENTED "feature" of the Prince valves so others may find out the EASY way... Steve
Steve,
Thanks for the heads up!
ac
/ Help me put together the ULTIMATE aux hyrdaulic setup. #19
1 thing about the sv series valves, they appear to have a tendency to leak a little more than some other valves. That can translate into your top, tilt, or both not staying where they're set as well. They're still a good valve, and not all the valves have the issue.
So is there any disadvantage to getting all of my valves (except the motor) with float?
ac
UNUSED INDUSTRIAS AMERICA HYD POST PULLER (A60430)
UNUSED INDUSTRIAS...
2004 VOLVO EC290B LC EXCAVATOR (A62129)
2004 VOLVO EC290B...
2008 GMC W4500 4X2 14FT BOX TRUCK (A59906)
2008 GMC W4500 4X2...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2014 F-150 STX (A56438)
2014 F-150 STX...
TRANSPORT SYSTEMS 35LX AD DOUBLE DROP (A60736)
TRANSPORT SYSTEMS...
