Kubota Modifications
/ Kubota Modifications #1
AU247365
Vinemont, Alabama
2004 kubota L2800
New owner of L2800 with Loader. Looking for ideas for adding work lights and mods for the bucket
/ Kubota Modifications #2
Welcome.
This is what I did for lights on my B3300SU
Tons of stuff in the Customizing section that would work for you. Doesn't matter the brand of tractor for these mods, any colour will still give you some more ideas
/ Kubota Modifications #3
Nice work Farm Boy, the switches look factory. Nice placement.
/ Kubota Modifications #4
What all do you plan on doing with the tractor? Mowing, grading, clear brush, this will help us to give you some ideas, some cheap, some not so much. ;)
/ Kubota Modifications #5
Welcome to the Forum.
Here are some light brackets I made for the BX out of a piece of angle, flat stock, and carriage bolts.
I added the switches to the light. There is a link in my signature on how to do that. I like the color that LEDs put off.
For your bucket mod's start by adding some weldable grab hooks to it.
/ Kubota Modifications #6
I agree that the bucket hooks are the most useful mod. It only took me a dozen years to learn to weld and put them on!
/ Kubota Modifications #8
A spill guard is nice for the bucket,allows for a place to add hooks.This is what I did on my previous L3240.P1000234.JPGP1000247.JPG
/ Kubota Modifications #9
A tooth bar provides a thick edge to strength the bucket, something you don't have with bolt on teeth. Of course, it depends on how you will be using it. I hit a lot of rock with my digging (skid steer) and ended up with a dedicated tooth bucket. Of course, everyone's needs are different.
/ Kubota Modifications #10
Welcome.
View attachment 336099 View attachment 336100 View attachment 336101
I thought of mounting my lights low like yours, my concerns
I wear glasses, any glare/reflections with lights at eye level behind your head?
When turning to look rearward don't they shine in your eyes?
I see you have a little bit of shielding ,was that enough?
/ Kubota Modifications #11
Thanks, that was the intention. Took some work to find the right ones.
I also wear glasses. The shielding was needed for two reasons.
When I first mounted the lights, I didn't have the shielding and couldn't even use the front light. It would reflect off my glasses while driving forward and obviously blind me when I turned to look backwards as I was looking straight into it. I knew I'd need the shield before I mounted them but needed them mounted to figure out the size of the shield. It's about 4" wide and covers from about the 10 o'clock position to the 4 o'clock position, held on with a stainless hose clamp. Another 1/2" of coverage would have been good but works well enough as is. I made it thru all last winter's snow removal with it like this. I'll probably play with it a bit when I get around to mounting the other pair of lights on the other ROPS post.
With the hyd valve also now mounted, I can raise the valve another 1.5 - 2" which I plan to do
/ Kubota Modifications #12
All you guys do some nice work :thumbsup:
Mine is a little rougher.
Your L2800 is similar to my L3010. The flat rear fenders make it easy to add a big (or small) tool box. I also added a grapple with the grapple control lever beside the loader lever.
/ Kubota Modifications #13
Very nice, I like the extra teeth on the sides of the bucket. and the second lever looks factory. That tractor is ready for WW III
Use will be bush hogging and land clean up. Maybe a little on the small side of tractor size for now. Working to clean underbrush on 20 of 40 acres
UNUSED JCT 2 PRONG BALE SPEAR (A62131)
UNUSED JCT 2 PRONG...
2016 Doyle 10T Tender (A61307)
2016 Doyle 10T...
2012 Ram 1500 4X4 Pick-Up Truck (A61568)
2012 Ram 1500 4X4...
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A63118)
Case Wheels for...
UNUSED LANDHERO LDH-LB9510 LEAF BLOWER (A62131)
UNUSED LANDHERO...
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
