Drawbar hitch help.
/ Drawbar hitch help. #1
crreed67
Central WV
Massey Ferguson 1635
Anyone know where I can get a hitch like the one in the picture, notably #'s 25, 26, 27, and 28. It comes on a MF 2615 among others and I want to put one on my MF 1635. I measured all of the holes and everything will match up on my drawbar. Aside from going through a dealer are there any aftermarket options?
/ Drawbar hitch help. #2
I think you'll be stuck with going thru the MF dealer. I can't imagine anyone producing these as an aftermarket add-on. Not enough demand for that. Good luck in your search though!!!
/ Drawbar hitch help. #3
You might look at two options:
1.) See what a MF dealer wants for the part
2.) Find a standard drawbar and ask a machine shop what it would cost to modify/fabricate to what you want.
See which option is cheaper. That would not be a difficult part to fabricate.
/ Drawbar hitch help. #4
get a piece of flat steel heat and make your bends, drill holes
Fabricating is something I do not have the ability to do and there aren't any machine shops in my area to request help from. I guess I'm gonna have to bite the bullet and talk to a dealer.
/ Drawbar hitch help. #6
... there aren't any machine shops in my area to request help from.
You might find a blacksmith, even a hobby one, to make it.
Bruce
I wish. There's only lazy worthless welfare idiots where I'm at.
/ Drawbar hitch help. #8
Looks to me like you could find everything on your list here
Hardware
Except for the bar to add on, which you might be able to use a hacksaw and drill to modify this
Swinging Drawbar
Although it doesn't say what the offset is - probably a LOT cheaper than other alternatives though... Steve
/ Drawbar hitch help. #9
I take it you have the draw bar & basically just need the top "Z". (Bolts pins are easy to find.) This if available from the dealer really shouldn't be to expensive. If it is, look for a tractor salvage yard. In Missouri "Cooks Tractor" is close to me & real handy to find treasures to build/modify with.
Yep. The "Z" part is pretty much it. I guess I'll check with the dealer. Did a quick check an Cooks website but turned up nothing. Will try the link that BukitCase posted for the hardware.
Hardware
Swinging Drawbar
Thanks for the links.
2022 Mack Pinnacle T/A Wet Kit Day Cab Truck Tractor (A64556)
2022 Mack Pinnacle...
2024 CATERPILLAR 299D3 XE SKID STEER (A65053)
2024 CATERPILLAR...
2019 Ford F-150 4x4 Ext. Cab Pickup Truck (A64556)
2019 Ford F-150...
199 (A64278)
199 (A64278)
2022 EZ-GO ELITE...
2016 John Deere 85G Midi Excavator (A64553)
2016 John Deere...
