Tire Valve Stems
/ Tire Valve Stems #41
I just replace 4 low pressure stems for high pressure last week on my boat trailer. Called my local tire shops and both wanted $20/tire to replace. Called Walmart and asked if they had HP stems and they did them for $3 per tire labor included. I had to take the tires in as they won't remove wheels from trailers. How can they pay someone to do that for $12 materials and all? They didn't completely unmount the tire, just one side.
/ Tire Valve Stems #42
Appreciate the info...
A few years back the tire shop put in rubber stems on my trailer with 60 psi inflation...
I asked to see the box and the stems were 50 psi rated... they put in metal.
Never had problems with rubber stems until recently...
Had 3 flats in the last 5 years and they were all rubber stems that went bad... two were on a BMW with 42,000 miles..
/ Tire Valve Stems #43
High pressure stems should look like this (just make sure you get the right diameter for your rim hole):
2016 Chevrolet Caprice Sedan (A61569)
2016 Chevrolet...
iDrive TDS-2010H...
2025 IRET13 Electric Tricycle (A60352)
2025 IRET13...
2025 Heavy Duty Booster Cables (A61568)
2025 Heavy Duty...
2025 Pabreak Auger Bits and Plate Skid Steer Attachment (A61567)
2025 Pabreak Auger...
PJ Trailers 84"x15' Roll Off Dumpster (A60462)
PJ Trailers...
