Asv rc-50
/ Asv rc-50 #1
Jaymo396
Hamilton, Ohio
Asv rc-50
I have an asv rc-50 and after I run it for an hr or so then shut it off it won't start. If I jump it or charge the battery it fires right up and runs until I shut it off again. If I charge the battery to 100% I can shut it off a few times before it won't start again. There is a alternator diode that looks like a fuse in the fuse box. Does anyone know or had this problem before? If that diode is bad will that cause this to happen? I replaced the battery soi know that's not it. I guess it could be the alternator but it cost over 300$ so I'm hoping someone out there knows what it could be. Thank you!
/ Asv rc-50 #2
I have an asv rc-50 and after I run it for an hr or so then shut it off it won't start. If I jump it or charge the battery it fires right up and runs until I shut it off again. If I charge the battery to 100% I can shut it off a few times before it won't start again. There is a alternator diode that looks like a fuse in the fuse box. Does anyone know or had this problem before? If that diode is bad will that cause this to happen? I replaced the battery Was it tested? so i know that's not it. No, you don't know, you are guessing, what is the voltage at the battery terminals? I guess it could be the alternator but it cost over 300$ so I'm hoping someone out there knows what it could be. Thank you!
Buy a digital multimeter and troubleshoot the problem.
Watch this video to learn how. Starter Voltage Drop - YouTube
Battery voltages here: Car Battery Tester - How to Test a Car Battery
