Buying Advice Diesel generator for home back up use
/ Diesel generator for home back up use #1
huntgrouse
US
Kubota BX 25
Maybe this is the wrong section. I am new to Tractobynet so forgive me.
I live in the rural northeast. back in 2011 we had sever power outages. I want to get a home generator to address that potential problem. Power was out for 6 days so I need more than a small 2-3KW. I want a diesel since I have a Kubota tractor and have diesel around and also have oil heat and two 275 gal. tanks to pull from. . Plus diesel doesn't have the long term storage issues that gas does. In NY all fuel oil is now low sulfur so its exactly the same as diesel except for color. When power goes out , the one gas station in town cant pump and las t long term outage the roads were closed and we couldn't even get to a town with power.
so, the logical solution is a generator , running on diesel/fuel oil. Researching the market, all I see is up to 7KW and then its a 4x price jump to go to 10-12 KW.
Trying to find prices for Kubotas smaller diesel generators or anyone else's for that matter is difficult There are plenty of Chinese 7KW out there but they concern me with all the poor reviews.
based on my rough calculations I need 10 KW.
anyone have any suggestions, ideas, recommendations?
/ Diesel generator for home back up use #2
Welcome!
How about a 3pt pto-driven generator using your Kubota? Cheaper but it does tie your tractor up when in use.
10KW is a lot of power for a typical household. How sure are you that you need that much?
/ Diesel generator for home back up use #3
Welcome!
Agree that a PTO generator would be ideal. One less engine to maintain, cheap-ish, and plenty of juice to run the whole house.
/ Diesel generator for home back up use #4
10 KW is not that much power if you have a total electric house. For my house I would need a 20 KW genset and still would have to block out one set of heating coils ( I have a heat pump but it draws on electric coils if temps get to low for the heat pump to function) if I wanted it to function same as with outside electrical power. You could get by with basics on 10 KW if you have gas heat, stove and water heater. Lots of diesel gensets out there from major manufacturers but expect to pay upwards of $10K for one. A pto genset would be your cheapest option but may not provide clean power as tractor engines don't react quickly enough for adding load to a generator so the frequency and voltage might fluctuate a bit as you kick on power robbers like AC, electric heaters, etc. This is not good for electronics.
/ Diesel generator for home back up use #5
Store some gas, buy the cheaper gas generator. Rotate the gas in your every day driver and use a bit of gas stabilizer in it which makes it store 2 years. Run the generator for only a few hours a day, any more and it's wasting gas. Store enough gas to get you through a few weeks. You may be able to get two generators for the price of one diesel generator.
2 is one, and one is none.
I do agree diesel is the way to go, but its cost is a hurtle.
/ Diesel generator for home back up use #6
Another vote for PTO.
/ Diesel generator for home back up use #7
This is what I do too.
We have two gas cars, so on average there are 15 gal of gas sitting around in them, plus the 10-15 gal. I keep on hand in 5 gal. cans. That's a lot of generator run time. In really cold weather--I assume you have oil heat given the two tanks--you do need heat every couple hours probably unless you are set up with a wood stove.
Some of the generator strategy involves reducing your dependence on having power, especially for a prolonged outage.
I've never had to tap the car's gas tanks but I am prepared with a siphon tube/bulb gizmo.
/ Diesel generator for home back up use #8
There are a few deals out there on 10kW gensets on Craigslist. Most cell sites use 7kw ones, so that size is common on the used market. If you dont mind working on one, you can get a used military 10-12kw unit (MEP-003a) for $2kish (or less) through Government Surplus Auctions at Government Liquidation. You can also get one that has been gone through from Green Mountain Generators for $4500ish.
I would HIGHLY recommend researching them on steelsoldiers.com and/or smokstak.com first as there are some gotchas to be aware of before buying one.
/ Diesel generator for home back up use #9
I would get by with a 6k genset if possible and a good choice would be this 6500w Honda. Honda EU6500iS Generator 6500 watt Inverter, Super Quiet | Wise Sales
If you are sure you want diesel then look into a Cummins Onan quiet diesel also available at wisesales above.
I have both Hondas (gas) and Onan commercial quiet diesels both are very good and much less noise than most you see today.
If you wan't to save some coins I agree with others about a pto genset for your Kubota. I usually recommend a standalone genset if people have kids as it would be safer than them fooling around with a running tractor for days.
/ Diesel generator for home back up use #10
Or get a decent cheap side gas genny like a generac for not a whole lot of money, and a pti as a back up if you can't supply gas.
I found this site, it give you an idea on price for disel back up generator. You can see the Perkins are a lot more money then the chineese. But the chineese have laidon engien, wicj I think is not so bad. But it s you call..... I am not related at all to this site: http://www.auroragenerators.com/.
I personnaly 10kw is a lot for the basics. But everybody have there own need. Me, eventually the goal is to build a 3kw gen with a 6/1 listeroid engine.....
/ Diesel generator for home back up use #11
Welcome!
Our place is 3,400sq ft, and we have a 20KW Generac hooked up to natural gas. It's capable of running everything, including the central air,which is pretty much necessary.....last outage we had it was well into the 90s, and we would have baked.
/ Diesel generator for home back up use #12
OP -
Do a search on generators on this forum. There are several EXCELLENT and LONG threads. Very little has changed in the last few years besides the relative lower price of natural gas..
I've a 12kw PTO almost unused I got for $600. I've a 6.5KW Honda powered I paid about $600 for a few months after Hurricane Isabel. And I've two of the little HF 800 watt. The HF get's used the most.
/edit - right now there is a 40KW PTO on the NVA CL for $1050.
And remember folks a BX 25 can probably only drive about 8KW anyways.
/ Diesel generator for home back up use #13
How much of the 20KW are you actually using? Peak? Average? Unless you know, then it doesn't matter how big the generator is.
The OP lives in a rural setting in NY. Chances are, he will survive without AC. :) I'm sure AC is nice to have in your location, but unless you have a compelling medical condition, you would also survive.
My 6500W generator will run my house. Well pump, water heater, lights, microwave, refrigerator and small chest freezer. I cook with propane, heat with wood and sunshine, and it would be a long outage before I would really miss using the washer and dryer. With some manual power management, the dryer could be used. It wouldn't surprise me if the generator breaker tripped if the well, water heater and refrigerator all ran together. That would not be hard to manage either.
No point in overspending for generator capacity that will never be used.
/ Diesel generator for home back up use #14
And more importantly, no point in paying for the extra fuel in an emergency situation when fuel is limited to spin a 20kw genset when a 7kw one would work just fine...
Aaron Z
/ Diesel generator for home back up use #15
Dave,
We can't spend much of the OP's money if we are sensible about this.
/ Diesel generator for home back up use #16
Dave,
Yeah, you are right. :laughing:
I'm not trying to tell the OP what size gen. he needs. His estimate was 10KW as I understood it. Could be right, or not. But suppose it's really less and he passes up a good generator value because he thinks it is more? We should help him save on the generator so we can spend that money of his somewhere more useful. :D
/ Diesel generator for home back up use #17
If Diesel PTO driven is out, ill throw some support behind jenkinsph of the EU6500is honda, its a very nice unit that makes clean power and isnt overly hard on gas (inverter with smart throttle). We have the EU7000. Its been 100% reliable. Only problem is the battery dies if the generator is not exercised regularly. That battery is foolish money too, something like $200+. Its a bit of a unique size, real small. Smaller than an ATV battery.
I agree with the others, no since buying more generator than you need. Some people want to just flick a switch and live like there is no outage...Thats not really prudent IMHO. That costs, not only for a large generator, but larger supply wiring, higher operating costs and less available run time for a given amount of fuel. Even my genset at 7000w could be considered overkill let alone 15 or 20kw.
/ Diesel generator for home back up use #18
craigslist littlerock Ark. for a 20 KV diesel generator on a trailer for 6250 or without trailer for 5250. It has a Daihatsu engine.
Some of us are not fortunate enough to have access to natural gas and propane is too expensive to use for heating so total electric is what is left. During long power outages, 7kw gensets wont run much other than a few lights and freezer/ fridge/microwave/tv and maybe not all those at the same time. If you cant live in comfort during an outage, then why have a generator at all, just break out the Coleman stove and lantern, put your sleeping bag under a nice shade tree and wait it out if in summer. Winter- got some wood for campfire. I don't think the wife would be too happy with that though. Time to go for a visit with kids or relatives if no big genset which I don't have.
/ Diesel generator for home back up use #19
How often does your power go out? Is comfort really a criteria, any generator is comfort relative to candles! With a 7k set you can run all the house with careful balancing of loads. Heat? fire up the woodstove or run an electric space heater. Far from roughing it.
Having to buy a larger unit and the larger wiring and other costs for a 20kw dont pencil out for a few hours a year without power.
/ Diesel generator for home back up use #20
Gary,
I have heard, but have no personal knowledge of it, that not all gen sets are created equal. Honda was, probably still is, known for being a gen set that actually produces what it says it will. My generator is a Honda unit.
If you have a 7KW gen set that won't power that list of stuff you mentioned, something is very wrong somewhere. The length of outage is really immaterial to the gen set, except for fuel supplies. You can have generators load tested.
The electric heat is a killer, no doubt. Typical/standard electric baseboard heat uses about 250W per foot of heater unit I think. Even that is not a constant load, it cycles on and off. You should be able to run an 8' section, and that other stuff you listed with a 7KW gen set without it breaking a sweat.
2025 Unused SDLGC80 60v Electric Golf Cart (A60352)
2025 Unused...
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A55315)
2017 KINZE...
2017 CATERPILLAR 120M2 MOTORGRADER (A59823)
2017 CATERPILLAR...
Westfield Conveyor (A61307)
Westfield Conveyor...
2007 DRAGON 130BBL VAC TRAILER (A60736)
2007 DRAGON 130BBL...
2014 International WorkStar 7400 Service Truck with Crane, VIN # 1HTWGAAR1EH765285 (A61165)
2014 International...
