Jd 3720 broken into pieces
/ Jd 3720 broken into pieces #1
Rockgod
CNY
JD X380 Accel 48" Deep Deck
:thumbdown:
I don't mind one, two or three small issues with a new machine, but this is getting crazy. I think this tractor might have been built on a Friday.
1st fix was the rear window. It sat right down on the rear fenders it actually scraped paint. Dealer came out and had to drop the tank to fix problem. Took an hour or so, not a big deal I guess....
2nd fix was a leaky gasket. Steering pump leaked oil all over the engine. Dealer came out took everything apart installed new gasket took a couple hours. No big deal I guess...
3rd,4th and 5th fix delt with my front blower/tractor. Tractor blew two hyd. rams on the blower. The 3rd time out the dealer checked the tractors pressure. It spiked too high so he turned it down. Guess we'll see if it worked haven't used it too much (winter ended) so we'll see...
Now this. It just sucks... :(
/ Jd 3720 broken into pieces #4
I hate to say it Rockgod..............That Kubota you got rid of is looking better all the time.
/ Jd 3720 broken into pieces #5
That's a crying shame.
/ Jd 3720 broken into pieces #6
Maybe I'm missing something...why is it split?
If Roy is missing somthing, I'm missing it too. What's gone wrong with it now, and did the dealer do all the work at your shop, including splitting the tractor?
It doesn't go/stay in high range (c) right I get a grinding noise going down the road. This is mostly when I throttle down from high speeds..
LOL, I'm not quite ready to say that.... Not just yet;)
Those are the photos I took today at their shop. Everything else I mentioned was done at my house.
/ Jd 3720 broken into pieces #10
Good luck with it. You could certainly use some for a change.
/ Jd 3720 broken into pieces #13
A friend of mine recently purchased a new JD combine for $400K+ and it has been in the shop since it was delivered...not a happy camper.
/ Jd 3720 broken into pieces #14
Did he miss harvesting with it? That would really tweak me after $400k
/ Jd 3720 broken into pieces #15
They had a factory rep onsite for days trying to figure things out. Luckily they had other combines and finished but are currently looking at Case once they settle with John Deere.
Update:
Good news, the 3720 is back together. :D
From what I can tell everything seems to be right. I mowed for 2 1/2 hours today and it ran great. Took it down the road and it seems like a different tractor. No noise in high range, and it ran smooth!
No exactly sure what was replaced (they don't give you a print out) but the tech told me, shift fork, gears, sleeves springs, detent balls? They also recharged the a/c.
Anyway, I'm off the ledge for now. I hope this is the last of it.
2009 PALFINGER 11 FT SERVICE BODY (A62613)
2009 PALFINGER 11...
2016 Chevrolet Express 2500 Cargo Van (A64556)
2016 Chevrolet...
Case IH STX 375 (A64126)
Case IH STX 375...
John Deere X500 Riding Lawn Mower (A66285)
John Deere X500...
Spartan RT-HD Zero Turn Mower (A66285)
Spartan RT-HD Zero...
Bush Hog 3Pt Post Hole Digger (A66408)
Bush Hog 3Pt Post...
