Red State
Greetings ALL, I'm new here and have posted my first thread in the wrong place so I'm trying to re-post it here (the FORD New Holland board). I'm a first time diesel owner and proud owner of a Ford 600 and a Ford 1700 (which I LOVE by the way). I'm not too knowledgeable on the diesels so, for now, I'd like to know what hydraulic fluid I need to stock up on. I don't need it but it'd be good to have (just in case). My only problem with the 1700 right now is that it was absolutely perfect for a few days of grading the drive-way and FINISH mowing my large yard. I wasn't till I took it over to my hunting place that I saw how tempermental this tractor could be. After two or three hours of bushogging, it began to burp some coolant and then a bit of steam. There is NO oil in water or water in oil....there isn't even any small, carbonated COKE-like bubbles or large bubbles.......just a smooth, even flow of clean, green coolant. I had to stop and clean the debris from the 4-5 foot weeds and it did fine until I really worked it so it could simply be that both I and the tractor were working too long in too hot of an old dusty day. I do notice it doing a little burping of coolant when I'm going faster and pulling or lifting heavy loads.
So, I many need to change the air filter or intake if that is what it is called cuz I've read some of the posts you guys have posted about other such problems. One that I read even said that if the belt is too loose it'll overheat a bit but if too tight it'll ruin the alternator. Mine seems perfectly tight but I did nit-pic and notice a slight wabble to the fan pulley. I'm probably just nic-picking everything cuz the tractor does what is needed and when it is needed. I suppose I'd simply appreciate some info on the hydraulic, oil and coolant that you guys prefer to start me off with. I'm not sure what year it was made so I may need some help in getting the correct owner/operator manual. Any help would be appreciated and once we get all that out of the way, perhaps we could simply talk about what we like most about these great little tractors.
The other thread I started is below....
NEW 1700 Ford Tractor owner...
