Trailer tire milage
/ Trailer tire milage #1
minner
Arab, AL
Kubota M7040 cab
What kind of milage are y'all getting from your tires? I've got 5k miles on this last set on 10klb tag consistently hauling 6klb. I will be luck to get another 1,000 mi before they need replaced.
/ Trailer tire milage #2
I cant help there, I never put enough miles on a trailer to wear out tires. I did some farming 40 years ago and owned 40 foot cotton hauling trailers. Put about 40 miles per day on them for 4 seasons and they didn't even show any wear. I would think something is likely out of alignment with your axles if you are only getting 6K miles. Maybe you aren't running properly inflated tires also.
I would do a check on the axle alignment to see if they are setting square with the frame.
Whew talking about a pain to tow and hard on a truck believe me I know.
Realistically though those trailers probably only saw the gin probably a dozen times a year?
FWIW most trailer tires are "rated" for 5k-12k miles.
/ Trailer tire milage #4
15,000 miles tops.
More important is age. 6 years max, after that I will not touch them and no tire shop around here will either.
Chris
/ Trailer tire milage #5
On our 15k 5ver I upgraded the tires to g-rated Goodyear g-614. They are 14 ply but with nearly 8k miles, they still look new. If I had to guess I'd say maybe 80-90% remaining. Honestly can't tell any wear yet. They are expensive but worth it in my opinion.
Brett
/ Trailer tire milage #6
Brett
Time is the enemy. 6 years plus they will be a ticking time bomb no matter how much tread is left.
Chris
/ Trailer tire milage #7
Chris
It's only two years old so I figure I've got plenty of time. Zero blowouts or tire probs
Brett
I'm not sure why we are talking about time, it shouldn't be a factor in my case. Mine are 1 year old.
/ Trailer tire milage #9
My 10K equipment trailers actually wear pretty well. One of them had the tires replaced due to age and not tread depth. Prolly had 6/7k on them and still had plenty of tread. I have a 7K enclosed trailer that gets less than 6 k between tire replacements. The axles are further back on the enclosed trailer and I think the scrubbing when I turn causes them to wear faster.
/ Trailer tire milage #10
something sounds clearly bent/out of alignment.
my 10K trailer has several thousand miles on it (regular 300 mile trips to our other property) in the past couple of years and the tires hardly look like they have lost any tread and its a used trailer at that.
Describe the wear? flat spots? (are you frequently locking up the trailer brakes) inside edge, outside edge, chunking?
Pics of the trailer?
/ Trailer tire milage #11
Do you rotate the tires? I do mine yearly which helps. Most chose hard left hand turns which scrubs more.
Chris
Nothing abnormal really. Wear is pretty even. The right side may a have a little more wear.
These are bias tires and I have not rotated them.
I know that's probably bad but I don't have a lot of spare time since mowing and tractor work is my second job.
/ Trailer tire milage #13
I have a 24' gooseneck with 2 - 7000 lb axles. The trailer came with 10 ply tires and I kept having to replace them with hardly any wear. The problem was that the belts would separate and the tires would blow out.
I think this was caused by turning to sharply with a load on the trailer.
I have switched to 14 ply and have not had any blow out since the switch.
/ Trailer tire milage #14
I have the same problem with my 7ton trailer swapped over to 10 ply truck tires. no problems yet
/ Trailer tire milage #15
Well the closest gin was over 20 miles away and they went once, sometimes twice a day for 60 days each year. I saw the trailers at one of the gins 10 years after I quit farming an the same 12 ply tires were still on it, a bit weather checked but still functioning. NO Brakes on those trailers then so stopping was a bear along with starting off. Pulled them with a 1500 GMC with 3 speed automatic & 350 CI V8. 40 MPH top speed with 12,000 pounds of cotton on it. The tires were 10:00x16 12 ply co-op tires, never had a problem with them either. I don't think they make tires to last like that anymore.
/ Trailer tire milage #16
When you replace get radial tires. We run Greenball Towmaster Radials on 95% of our stuff. Bet I have been around for a hundred sets on tandem and tri axle trailers and not one single failure unless age related which I always warn the customer about and refuse to hitch up to if over 6 years old.
The Goodyear Marathons and Carlisle's had so many failures I could not keep track.
Chris
/ Trailer tire milage #17
15,000 miles tops.
Chris
Never knew that I got a sixteen foot tandem with the original tires from 99. I use it to haul hay twice a year and odds and ends. The spares in good shape too lol
/ Trailer tire milage #18
How many miles and what speeds?
I have personally had two spares let go without ever touching the ground. One happened not 5 minutes after my daughter was next to the trailer in the pole barn putting away her bike. It blew a hole through the wall. Ticking time bomb. It was 8 or 9 years old and a 225 75 15 Carlise 8 ply.
Chris
/ Trailer tire milage #19
Chris
How can you tell the age of a tire? Isn't it on the tire somewhere?
/ Trailer tire milage #20
Yes. Its in a oval about 1.5" long and .5" high. It will be a code like 3408. Its always 4 numbers. In this example 34 is the week and 08 is the year. So the tire was manufactured the 34th week of 2008.
2112 would be the 21st week of 2012, ect.
Chris
2015 Freightliner M2 106 AWD Altec DM478BTR Insulated Digger Derrick Truck (A60460)
2015 Freightliner...
UNUSED WOLVERINE 7' FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
2014 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2014 Chevrolet...
Caterpillar C18 Industrial Diesel Engine - Serial N8F01109 - Arrangement 385-7728 - Pump Takeout (A63689)
Caterpillar C18...
2018 Bomag BC572 Articulated Refuse Compactor (A61572)
2018 Bomag BC572...
2016 Ford F-550 Ext. Cab Enclosed Service Truck (A61573)
2016 Ford F-550...
