John Deere Trans Oil
   / John Deere Trans Oil #1
narampa
canada
445 johndeere
Anybody have any Idea where I can find a compatibility chart for oils for John Deere.
John Deere Hy Gard is what I have been using as I know the wrong oil in the transmission can be a real bad thing.
The temp range I operate in -40 to 100 deg.
Not looking for opinions just facts.
   / John Deere Trans Oil #2
I have looked and never found a solid list that I would trust my investment to.
You don't lose much fluid in the way of day to day operations. Just if there is a leak, which you need to fix first.
IMHO, If you are replacing the fluid won't you already be at the dealer getting new filters? That is what I found and buying 30L of Hy-gard is around $100 a small investment for a $40000 tractor.
I agree with you however the tractor is in a remote area and the nearest John Deere dealership is miles away. We have a good store of filters but oil is a problem for the distance as everything is flown in by small aircraft. John Deere dealerships are are 300 miles. But the fuel dealers are closer and we would like to have oil that is compatible.
I know what you mean by trusting a list.
But I thought I would ask.
   / John Deere Trans Oil #4
I will tell you what I tell all the Kubota owners, John Deere doesn't make hydraulic oil. Someone makes it for them and puts on a sticker. It is the same oil that others sell if it meets the John Deere specifications. Lots of oil meets JD, Kubota, NH, Case and many others in the same can. The specs are written right on the cans as to which specs the universal oil meet or exceed.
Just check the labels to see if they list the equivalents to the universal hydraulic oil.
   / John Deere Trans Oil #5
Even though it's a hassle, I do recommend using the Deere brand oil. Hydraulic fluid isn't changed that often and that extra bit of hassle may be be very worthwhile.
I don't have a lot of choice at the moment as the oils that are available are missing one spec that that John Deere requires. So for the time being I am going to sit tight.
Fuel supplier is going to see what he can do.
I know exactly where your coming from I worked 30 years for an oil company.
   / John Deere Trans Oil #8
PRODUCT
Product Name: JOHN DEERE LO HYGARD TRANSMISSION & HYDRAULIC FLUID
Product Description: Base Oil and Additives
MSDS Number: 12940
Intended Use: Hydraulic/transmission fluid
COMPANY IDENTIFICATION
Supplier: Imperial Oil Products Division
240 4th Avenue
Calgary, ALBERTA. T2P 3M9 Canada
   / John Deere Trans Oil #9
A number of years ago John Deere used to source at least some of their HyGard oil from Mobil with Mobilfluid 423.
I used to work for Mobil in Industrial Lube sales.
   / John Deere Trans Oil #10
Low bid, always low bids get the contract.
Thanks for the information I will look up Mobile.
And I am going to look up Imperial oil in Calgary They may be of some help.
Great information guys!
Thank you
   / John Deere Trans Oil #12
Here you go (not like you couldn't look it up yourself, just a courtesy)............
Mobilfluid 424
I see in the vein of continuous improvement (or marketing) they've moved from Mobilfluid 423 to 424. Mobil "recommends" to replace JD20 HyGard, but of course Deere ain't gonna recommend nothing but their private label.
Ok dufus what makes you think I never found this?
   / John Deere Trans Oil #14
dufus? really? Is that how you typically respond to those trying to be helpful to you? If so, expect no future responses from members.
2020 PRINOTH PANTHER T14R ROTATING CRAWLER DUMPER (A60429)
2020 PRINOTH...
2011 FORD F-550 (INOPERABLE) (A55745)
2011 FORD F-550...
2019 Toyota Corolla Sedan (A55853)
2019 Toyota...
Caterpillar 2PD5000 5,000LB Diesel Forklift (A56857)
Caterpillar...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
2007 FREIGHTLINER M2 26FT CDL REQUIRED BOX TRUCK (A59905)
2007 FREIGHTLINER...
