GR2120 First Impressions
/ GR2120 First Impressions #21
I went to look at this 2007 GR2000 yesterday, I drove hours to get there and this "Garage Kept" "Like NEW Condition" was a big disappointment. I felt bad for the son that was trying to sell this for his widowed mother. However he had not a clue on how to present something to sell. I won't even get into all that was wrong with it.
You need to remember just last Friday I sold my 2005 GR2000 with twice as many hours on it and twice as clean for $3600.00 I didn't even make an offer. They wanted $3400. It is worth $3400 to them but I knew what my machine looked like and this was far from it. Oh well.
On the way back I stopped at two Kubota dealers and called two others and there just aren't many used Kubota's. Actually none.
The dealers you do call have used machines on their website but when you call them they mysteriously have none but want to sell you a knew one. Hmmm!
I'll keep looking.
/ GR2120 First Impressions #22
Aren't they 4 wheel drive, except when turning, when the glide steer kicks in?
Has anyone modified the discharge flap, so you can lift it while mowing when the extra space is needed?
/ GR2120 First Impressions #23
Yes, they are all 4WD, then as you turn, the inner rear wheel clutch proportionally disengages. See attachment.
This is how I modified my discharge chute.
Philip.
/ GR2120 First Impressions #24
Philip.
Not quite what i have in mind. Think I'll just put a eye bolt in it and use a string. Cant think of anything else right now...
/ GR2120 First Impressions #25
I know this has been asked before but does anyone know if Kubota makes a mulching kit for a 2012 BX1860 w/54" deck (not fine cut).
This has been answered in the past but I have found none that are current and want to know if one is available.
I had one for my GR2000 w/48" deck but since I have stepped up to the BX1860 54" I can't find any concrete advice.
/ GR2120 First Impressions #26
Try calling your local Kubota parts department. They will even tell you how much it is. Philip.
/ GR2120 First Impressions #27
Well....I may as well throw my .02 cemts in. I had a GR....05' vintage. Had nothing but trouble with it so I traded it in on a BX at 239 hours. Kubota DID put the transmision upgrade in at no cost to me, but I still had issues with the power and cut quality. It had plenty of power but was not able to get it to the ground. The tranny was very "weak"...espically in reverse. Even after it was fixed it started leaking again (but not from the axle shafts this time). I have to mow trversly across a slope and the cut was very poor at best (54" deck). The BX on the other hand has a perfect cut on the same slope.
I enjoyed the GR for some things and it was without a doubt more manurvable then the BX, but the bottom line was that they had some serious design flaws in the transmission....oh...and the glide steer cables....I had to replace them due to a design flaw....Kubota went halvseys with me on that.
The mower absolutly had the potential to be a really good machine. I hope they got all the kinks worked out before you guys got yours. Good luck!
Chris
/ GR2120 First Impressions #28
I have 25 hours on mine and it's working smoother now. Suppose it's broke in now. Getting ready to pickup my filters and fluids on my next trip to the USA (cheaper there) and will do the service after my last time cutting grass for this year. Even if i dont have 50 hours on it. Attach the blower and wait for snow.
/ GR2120 First Impressions #29
Pete6114,
Keep us updated on the progress with your GR2120. Several of us are a little gun shy from the original GR models. I never had any troubles with my "05" GR2000. My dealer went out of business in 06 or 07 so I never got any of the bulletins on the concerns for the transmissions in the earlier models. I figured what I didn't know didn't hurt me. It is a great tractor.
/ GR2120 First Impressions #30
I bought a BX1860 w/loader a month ago because I felt it was a step up from my GR2000. It was, but really for mowing I needed to get use to the BX fast because light wheel spinning was creating several muddy spots around some trees I mow on a hill. With the GR you didn't have that because all the wheels were driving. And if you kept the BX in four wheel drive all the time then you end up pushing the tractor on turns and causing more turf damage.
I tried selling my GR for a month to justify keeping the BX, however after several close calls I listed both of them on Craigs. Then out of the blue a man called about the BX, came and bought it for my asking price.
I agree the seat could be better. I have had my GR2000 since 2005, it's showroom condition but yesterday when I went to mow, I took two TYLENOLョ afterward. The way I explained it to my wife was with the BX1860 you sit IN the seat and IN the tractor. With the GR you sit ON the seat ON the tractor.
Does anybody have any suggestions or answers for a more comfortable ride on the GR. I would even spend the money to put a BX seat on the GR.
I just finished a cheap spring suspension mod on my GR2000.I have the B series seat which is thicker and that helped some over the stock seat but,it still rode like a rock.Didn't realize how bad it was till I got a Simplicity with a spring seat.Kubota actually advertised these first gen tractors as having a suspension seat.So,a while back I ripped the framework up to see if I could find it.There it was-a parallelogram hinged apparatus with a 3/4" solid rubber block in between-basically worthless.I tried some things like springs and a small inner tube instead of the rubber block but it just didn't suit me.So,I got to looking at it yesterday and come up with this;
A length of flat bar 3/16 X 2 wide fastened to the seat subframe with 10-24 tapped screws,then bolted 3" long by 2" diameter straight seat springs with 5/16" bolts.
Bought some vinyl covers to go over the springs from McMaster-Carr.I weigh around 240 and have an inch or so riding height before bottoming out so that should make a big difference.About 25 bucks invested.
Locknut,looks good.Let us know how it works after you put it to the test.Where did you get the B series seat and how much?If you don't mind saying.
/ GR2120 First Impressions #32
I honestly don't remember what I paid for it.Somewhere around 100 bucks?. It was 3-4yrs ago when there was a Kubota goodwill campaign going on to satisfy BX owners that had that worthless,nasty slide-off seat.They were available to dealers at a deep discount to sell or in some cases give away if need be.It sits a little higher but nite n day difference in comfort over the cheap lawn tractor seat.
/ GR2120 First Impressions #33
I'm about 240lb. Dont have a huge issue with the seat though. I adjusted it to my liking and am good with it. My only beef is that the steering wheel is so far away and a tad low....My arms are still bend a little, but my wife is reaching for the wheel.
I don't know if it would help but I am guessing that the higher steering wheel off the BX 70 series would fit on the GR as the wheel that it comes with appears to be the same one as on the BX 60 series.
/ GR2120 First Impressions #35
What brand Motor Oil do you all use in your 2120? In past Kubota tractors i had, it called for diesel specific oil, that i always bought at a dealer, but not calling for it in this little diesel. Just wanting CF or higher.
/ GR2120 First Impressions #36
Mobil 1 5w-40 TDT is what I use. There are many options out there, just make sure it is diesel rated API CH-4 CI-4 CJ-4. Philip.
I have used my GR about four or five times now,about twelve hours.I have noticed a couple of things that I wonder about,curious if other GR owners experience the same things.The first thing is that I can feel the clutch in the rearend disengage when turning.It is not a rough feeling but I can definitely feel it.The other thing is a noise when raising the mower deck.It only happens when the tractor is warm.I am assuming it is a noise from the pressure relief valve,but it seems to be coming from under the steering wheel where the hydraulic hoses are for the steering.When the tractor is cold,and the hydro fluid is thicker,the noise doesn't happen and there is only a small hissing noise from the PRV.After the fluid warms up there is a louder noise almost like a loud vibration when raising the deck or when on the PRV.I talked to the salesman and a mechanic and they both seemed to think it is normal.I am curious what other GR owners have experienced.
/ GR2120 First Impressions #38
I have a little over 12 hours on mine too. Grass has not grown very fast since purchase, hot weather and lack of water has put a curb on my mowing time.
I can feel a dis-engagement, but it is very smooth. Probably because I know it is suppose to do that.
The only noise I hear is when I raise mower deck to highest position, the raise lever does not return to center position, and there is a very loud squel until I return lever to center position. I will lube spring and pivot point at next service, hope that takes care of it. Not that big of deal, but if someone else operates it, they may not catch on so quick.
Philip
Thanks for the response,Philip.A loud squeal would better describe the noise I am hearing,I didn't describe it very well.Have you noticed the noise when first using the tractor or is it always the same,whether hydro fluid is hot or cold?When mine is cold I only hear a minor hissing noise from the PRV which seems normal.The last time I finished mowing the loud squealing noise was there.After hosing the tractor off with the garden hose,the noise seemed to be less so I am assuming the squealing noise is caused by the hydro fluid being hot and thinner.I am wondering if this is normal and if other GR tractors do the same thing.
/ GR2120 First Impressions #40
I will have to check, but I think it is when the fluid is at operating temperature. It only happens when the lift lever is in the stuck full up position after the deck has raised to highest level. I think the noise was coming from valve, but I will have to check that too, if we ever cool down and get any rain. Philip.
