Mahindra Max 25 hydro filter access
/ Mahindra Max 25 hydro filter access #1
pierpontjay
chardon, ohio
mahindra max 25
the FEL subframe on the max 25 restricts access to the lower (vertical) hydro filter. Is there a trick to removing the filter? Must the frame or fender be partially removed? Does mahindra offer a tech support contact? Thank you..
/ Mahindra Max 25 hydro filter access #2
pierpontjay, just go here, and enter your tractor's serial number: MAHINDRA USA TRACTORS 24/7 OWNER'S CARE
/ Mahindra Max 25 hydro filter access #3
I took the tire off and remove a couple of the bolts that hold the inner fender on the bent the inner fender out of the way. Kind of a cave man way of doing it. This winter I'll cut it off and bolt a hinge to it. What a mess huh.
Hey thanks for getting back on that. I took the same route. The fender came off just fine without removing the wheel. the whole side of the filter was then exposed. The fender was a little tricky to reinstall, but well worth it. There's also the front-most drain plug that is a challenge because of the subframe. A floor jack is a must.
2021 KUBOTA SVL95-2S SKID STEER (A62129)
2021 KUBOTA...
2012 Toyota Camry Sedan (A61569)
2012 Toyota Camry...
2025 GPS Trailer (A56857)
2025 GPS Trailer...
2010 Scag STT52V-27CH 52in Zero Turn Mower (A61567)
2010 Scag...
New/Unused Sickle Bar Mower (A61166)
New/Unused Sickle...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
