vista laptop - security center empty, firewall not on, can't update, add/remove prog
   / vista laptop - security center empty, firewall not on, can't update, add/remove prog #1
Soundguy
Old Timer
Central florida
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
got a vista laptop at work.. guy in the back office has been using it ( hp i think... )
i was updating virus software on stuff at work. get his..
security centr in control panel was empty. did not show firewall.. virus software..e tc.
manually going to firewall icon in control panel said fw not in use.. and you could not 'update settings'
also notice that add/remove programs icon is NOT in control panel?
what gives?
I have kaspersky on it.. no viri ( did have a few trojans i removed ).
used kaspersky's 'check damage to os' settings.. nothing came up.
any idea on how to get the firewall up.. or ANY firewall? is there one you can download?.
I don't want to unleash this guy back to the internet with NO firewall...
   / vista laptop - security center empty, firewall not on, can't update, add/remove prog #2
   / vista laptop - security center empty, firewall not on, can't update, add/remove prog #3
I'd suspect malware too. There's some nasty stuff out there that'll make a mess like this, the software can stop some services from starting like firewalls. Most happen by someone clicking a popup thinking they are stopping a virus when they are really loading it. I'd do a scan with Malwarebytes and Superantispyware to see if anything is found. Some of the malware has to be removed by running in safemode or before any programs are started. May be easier to grab the data and reload the o/s...Vista, ugh.
Good luck.
kaspersky is handling the malware.. did find some trojans.. etc..
hey now.. that MS firewall fixer looks like it's the ticket!
when i get back to work i'll try it.
if no go.. i'll try malwarebites in case kaspersky missed something.
thanks for the ideas guys!
   / vista laptop - security center empty, firewall not on, can't update, add/remove prog #6
Soundguy Look into M/S Essentials for protection . it is free and works .
Real time and virus and spyware.
I dumped the Vista and installed System 7 works like M/S should.
ken
oh yeah.. vista. not my fav either. ( XP actually was! ).
and it's the HOME version of vista at that.. ;)
not mine to do that with.. it's a work laptop.. :) but I hear ya...
ken
   / vista laptop - security center empty, firewall not on, can't update, add/remove prog #9
Some one sent me a attachment and it was also a McAfee download that I didn't request.
Locked up this lap top so that so slow would time out before could run the virus or spyware scan.
And slowly over a couple of months. removed programs until received a M/S Essentials notice that there was a McAFee program trying to install and getting blocked.
Removed what had been put in and all was well again.
M/S Essentials runs in back ground and never notice unless there is a problem.
Software download from M/S
Is the work laptop used by a blond.?
ken
   / vista laptop - security center empty, firewall not on, can't update, add/remove prog #10
Sadly, there doesn't seem to be any software that stops Malware completely if the user is bent on loading something that pops up. Often times the window looks like something that the anti-virus program found. This is one of the reasons I really like Firefox with the ABP plug in. No popups whatsoever from the browser.
12' CONTAINER (A52706)
2019 Ford F-350 (A55973)
2019 Ford F-350...
2003 International 7400 T/A Heil 12 CuYd Dump Truck (A55853)
2003 International...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2008 Ford F-450 Crew Cab Utility Flatbed Truck (A55973)
2008 Ford F-450...
2005 Sterling Acterra Tender Truck (A56435)
2005 Sterling...
