Hydraulic Drive Gear Failure
/ Hydraulic Drive Gear Failure #1
mesterly
Snohomish, WA
Branson 2810
I have a Branson 2810 with 420hrs on it bucket got jerky for 10 sec on light load hydraulic lost pressure.
I've checked the screen replaced the filter ( cut open it's case and inspected it to be clean ) fluid looks brand new etc. No grinding sounds just no pressure to the 3pnt and loader.
The Branson dealer is 2hrs away and said it sounds like the Hydraulic drive gear.
Question: Have any of you all opened that Hydraulic drive cover on the motor front? I'm thinking of trying to tackle the fix my self.
Thanks in advance,
>matt
/ Hydraulic Drive Gear Failure #2
Its been several years but from what I remember the whole front cover ends up coming off. The worst part about is getting the governor springs unhooked and hooked back up to the front cover on the right side. Better have a good selection of needle nose pliers. Otherwise, its pretty straight forward. Is the steering still working? Both pumps are driven by the same drive gear.
My steering does still work very well. This is great info that the same gear drives the hydro and steering. Glad I didn't crack the cover yet. I've been working a ton of overtime so the tractor is sitting at show waiting in line for diagnostics.
/ Hydraulic Drive Gear Failure #4
Why not pull the pump 1st before pulling the front of the tractor cover?
The deal said it was probably the gear so was going to work front back. I assumed pulling the cover was easier than the pump, is this incorrect?
/ Hydraulic Drive Gear Failure #6
My guess is I wouldn't thank so, if the pump is on the out side. 2 to 4 bolts and lines then should just come off. Now if it was in the trans housing that is another ball game. After you get it off should be able to see the gear or coupler and you can check the pump shaft to make sure it's not broken. Now I'm only guessing and might be all wet because I don't know much about your tractor.
Thankyou sir. I'll post back when I find out more.
Pump is off turns out the spline stripped on the pump drive gear. Pump doesn't look that great either ordering a new pump and drive gear. I'm surprised this would happen at 420hrs of light use. Everything else tight with no signs of wear on the tractor :(
/ Hydraulic Drive Gear Failure #9
What do you mean by "pump doesn't look that great either"? Does it look like the side plates and gear teeth have been sand blasted? Are the wear plates scored, etc..
Gear teeth are worm enough I wouldn't want to mate them up with a new drive. The shaft going into the pump housing has rust. I haven't torn into the pump.
/ Hydraulic Drive Gear Failure #11
I had the same thing happen on my branson 4020 a few months ago. Only has around 400 hrs and with out warning my three point and loader hydraulics failed. After around a month of trouble shooting the small stuff, like filters, fluid, pressure relief valve, and removing pump i was still dumb founded. The dealer told me the pumps almost never fail and it was likely the hydrulic drive gear, he said this is a common problem. Upon closer inspection I noticed that the inside splines of the drive grear were gone and the shaft of my pump were more like a triangle shape than the square spines. The spines on the power steering pump are still good and the steering works fine. I got a hold of a new pump and drive gear (right around $500) and was told about the govonor spring being a issue to getting the timing cover off and also that the gear has some bearings that need to be worked off. Dealer informed me that the govonor spring and linkage is on the right side around the injection pump and i need to take a access cover off to remove them. After looking at it I take it this cover is the oil fill on the right side of the timing cover? I have just started working on this project last night and have everything off the front of the tractor. Hopefully I will crack the case open tonight and get the new gear in if everything goes alright. The dealer told me that branson doesnt use gaskets that often and that the timing cover is is only sealed by a bead of silicone. I will keep you posted of my progress and if you have any questions I will do my best to answer them. Thanks
/ Hydraulic Drive Gear Failure #12
After around an hour of breaking bolts loose on the time cover i started to tackle the govonor springs and linkage. The first access cover was on the timing cover itself, on the right side and it had a oil fill spout (2 bolts 2 nuts). Once this is off I disconnected the link arm that was held in place by a small cottor pin and a small washer, "be carefull not to drop", invest in good set of needle nose. The second access cover is slightly farther back parrell to the loader brackets. It is larger and has six bolt and the throttle cables are on the outside of the cover. Their are two springs that need to come loose one has a U that is easy to remove the other is alittle harder to get disconected as it is hooked in a very small hole on the govonor linkage. Once these were off the timing cover came off pretty easy. The hydraulic drive gear had two bearings that needed to be taped off "be gentle". I then replaced the gear with a new one and began putting everything back together useing silicone to seal the timing cover. I came to a stoping point for the night when I was unable to reconnect the second spring that is hooked into a small hole. This would be much easier to see what I was doing if I could take the loader off the tractor. But with no hydros this isn't eaisly done. Hopefully tonight I can get everything put back together and fire it up.
Hopefully this will be helpful if you attempt to tackle this. I'm not overly mechanical and its still only taken me maybe 4-5 hours to slowly dismantle and reasemble to the point that I'm at now. With any luck I estimate that I should have it back together and working after a couple more hours of tinkering.
/ Hydraulic Drive Gear Failure #13
Hi guys!
New to this page, but I have a Branson 2810 with hydraulic gear failure, both power steering and bucket. Question: How many bolts are on the gear case? I've removed all the face bolts and one from each underside, but seem to remember some hidden ones. I don't want to break or pry the case. Any help is greatly appreciated.
/ Hydraulic Drive Gear Failure #14
Patcait04, Congrats on finding your issue and solution!
Gold Fender, if you have a dealer local they may be able to make you a copy of the diagram from the service manual. AND welcome to TBN!
/ Hydraulic Drive Gear Failure #15
Have the manual, no indication in it of where the bolts are. I took the bottom oil plate off to check, but no go.
I'd take the radiator off so you can get clear access. I sprayed about about a 1/2 gallon of degreaser on it, though I can't remember how many bolts. My gear was stripped, and the end of drive coming out of the pump was starting to go so I opted for a new pump. Good luck! BTW my pump and bearings were dry, oil just wasn't splashing into the housing, event tho there was no blockage so the bearings and spline are now packed with bearing grease... I know it could get in the oil but considering things were dry I figure grease was better than dry.
/ Hydraulic Drive Gear Failure #17
Thanks for all the help guys! I did get this response from the good folks at Branson regarding the "hidden" gear case bolts (hidden to me because I'm not a mechanic!!)
"Rex,
Please find attached file. It is pictures of the 2810 gear case. For the gear case to come off you have to remove the oil pan. If you have any further questions jus let us know.- Aaron"
I've attached the picture they sent me. Hope this helps anyone in the future changing the hydraulic pumps and gear bearings!
5ft 3 Point Hitch Rotary Cutter (A61166)
5ft 3 Point Hitch...
MANIFOLD TRAILER (A58216)
MANIFOLD TRAILER...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2019 Ford F450 Extra Cab 4x4 Service Crane (A62613)
2019 Ford F450...
UNUSED INDUSTRIAS AMERICA 170-7' SCRAPE BLADE (A62130)
UNUSED INDUSTRIAS...
UNUSED JCT 72" HYD BRUSH CUTTER (A62131)
UNUSED JCT 72" HYD...
