STORING ATTACHMENTS
   / STORING ATTACHMENTS #11
got a bunch of those HF furniture dollies for about same price as plain casters.
I've crushed a few of the HF dollies by lowering my bucket or grapple onto it without turning my machine off first, fwiw.
   / STORING ATTACHMENTS #12
Everything I have to store outside goes on top of either a free surplus plastic pallet or on left over sections of 6"x6" treated. I tarp/bungee cord everything and have seen very little paint fade or rust over the years.
   / STORING ATTACHMENTS #13
I have all mine on trollies on castors. Makes storage easy as you just move things around as required. It also makes it a a lot easier to connect the equipment to the tractor.
Weedpharma
   / STORING ATTACHMENTS #14
I just set them on the ground. I have a tiller, PHD, rear blade, and bushhog at my house currently. And another blade and bushhog at mom and dads. plus 3 ballast barrels (2 for the truck when snow plowing, one for the tractor), and the snowplow for the truck.
Obviously I dont have enough garage space for them. But outside, I have a nice stand of white pines. Grass dont grow, so I dont have to worry about mowing around them, or loosing them in the weeds. Good for stacking firewood between pines too:thumbsup:
Only issue is the pines are out front. So my wife things it makes the place look cluttered all the "junk" I have.:laughing:
   / STORING ATTACHMENTS #15
(so now I'm up to 107 projects to do around here... great. :rolleyes:)
Sorry to cause additional pain and anguish believe me it was just the evil side getting loose.:eek:
   / STORING ATTACHMENTS #16
Pallet's are perfect. They can normally be had for free.
Pallet racks are a good place to put pallets.
I like pallet racks.
View attachment 332946 View attachment 332947 View attachment 332948
The difficulty arises in getting the pallets above the reach of your FEL :)
I agree on pallet racks.
I found a crank up lift similar to this one on craigslist.
Mine is rated for 650 lbs. to 16' high.
   / STORING ATTACHMENTS #17
You have not told us what surface you are planning to store your implements on. However, If you have a cement floor, you can build pallets with casters to store your stuff. Pallets do two things for you - 1) makes storing the implements in the least space a breeze and 2) makes hooking up very easy as you can move the implement rather than the tractor. Most implements come on pallets when shipped to you or your dealer so using those pallets make it a lot easier and less expensive. On the other hand pallets are not that difficult to make and can generally be made with scrap lumber. A set of casters from HF costs about $20.
That's a pretty good idea! Thanks!
:beer:
   / STORING ATTACHMENTS #18
If you do the skid and caster route buy good 6" wheels. I went the cheap route and my Landplane skid split and broke when I tried to move it. Lesson learned.
   / STORING ATTACHMENTS #19
If you have a large enough, flat enough floor for individual pallets on casters, you might consider buying ONE pallet jack and making your pallets compatible - compared to several sets of DECENT casters that won't fail, the pallet jack may be cheaper.
'course, I'd rather go the pallet rack approach, and WILL if/when I find a good used fork lift AND get the shop addition finished... Steve
   / STORING ATTACHMENTS #20
<snip>
Don't wait - Pallet racking can be used as the structural frame for a small shed. If you can't find pallet racking for FREE you often can get it cheap if you scan CL every day. I got 7 sections (about 56 linear feet) of 12'Hx4'Dx8'W w/ 3 sets of shelves AND wire racks for $10/section.
If you look carefully:
you'll see that the first level of these racks are actually work tables. I put the supports down, then a 3/4" PT sheet of plywood, then a 3/4" sheet of plywood. Makes a great worksurface.
2002 VOLVO L150E WHEEL LOADER (A51246)
2002 VOLVO L150E...
UNUSED CFG INDUSTRIAL H15R EXCAVATOR (A52706)
UNUSED CFG...
BUNDLE OF 22" X 60" EXPANDED METAL (A54756)
BUNDLE OF 22" X...
UNUSED FUTURE BD43 HYD BACKHOE DIGGER ARM (A54757)
UNUSED FUTURE BD43...
9202 (A50322)
9202 (A50322)
