Converting to a joystick for FEL
   / Converting to a joystick for FEL #1
namyessam
Gold Member
guess where
xyz
I have a Massey 135 with an old Massey tubular style loader with a trip bucket. I built an auxiliary hydraulic system driven off the front pulley and currently use that for the single acting lift cylinders. I accuired an oversize snow bucket that forced me to convert it to hydraulic dump due to it not being balanced as the small manure bucket. I am running this for the time being off the tractor hydraulics. This setup is very awkward being the hydraulic levers are far apart. The trip mechanism for the manure bucket is not functioning properly so I am considering converting the manure bucket to hydraulic dump also. To improve the whole system I am considering adding a joystick to the auxiliary system to run the FEL.
Question; right now the pump is low output guessing 4 gallons (not much less than the tractor hydraulics at 4.5 gallons/minute) Can I or should I consider a regenerating valve to help speed cycle time and will it work with a combination of single and double acting cylinders. I understand that the unused line due to the single acting cylinder will have to go back to tank. The pump is an SAE mount and one with more flow should be easibly installed in the present mount and will be changed as funds allow. open center system.
Thanks for any help you can provide.
   / Converting to a joystick for FEL #2
Do you mean add a joystick lever to what you have now or install a new joystick valve?
replace the single spool single acting valve with a two spool double acting joystick valve
   / Converting to a joystick for FEL #6
That is correct.
Regen only occurs in the dump mode.
Tilt the stick right, for regular dump and more right for fast dump.
That is correct.
Thanks J.J. I'll get one on order.
I just received my special order Brand Hydraulics joystick through a local hydraulics retailer and it came with PB at no extra cost. I don't need PB right now so the question is do I remove it and plug the port or just plug the outlet of the PB? My understanding is if you remove it, you can use it for the return port and plug the other port. If I plug the PB will it continually blow the relief? Now have to wait for some warmer weather to make a mounting bracket, get the fittings figured out and purchase some different hoses.
   / Converting to a joystick for FEL #9
If you have a valve after the loader, and you should, you need PB to feed the pump flow downstream.
   / Converting to a joystick for FEL #10
Looking back to your first post, you are running this valve on a secondary (auxiliary) pump circuit that is not tied into the rear hydraulics. No you do not need the Power Beyond in this case, but you cannot simply plug it. Either run 2 hoses for tank return or remove the PB sleeve then run tank return from either that port or the "T" tank port.
Brock 5 Ton Feed/Grain Tank (A55301)
Brock 5 Ton...
SULLAIR 185 PORTABLE AIR COMPRESSOR (A51406)
SULLAIR 185...
2017 Freightliner MT55 Box Truck (A55788)
2017 Freightliner...
Electric Mobility Scooter (A51694)
Electric Mobility...
2018 Ford Fusion Hybird (A53424)
2018 Ford Fusion...
2007 GENIE GTH-1056 TELESCOPIC FORKLIFT (A52705)
2007 GENIE...
