3 point lift issues
/ 3 point lift issues #2
Being that old, the 3pt cyl seal might be worn, cracked or brittle.
It could be a worn valve, but it is probably the cyl seals that are leaking.
Try this, with a load on the 3pt, raise the 3pt, turn the knob to lock the 3pt for transport and wait 24 hr and see if the arms have dropped. This will tell you the condition of the seals.
/ 3 point lift issues #3
While I am bushogging my lift tends to leak down
Does lift leak down or does control lever vibrate down allowing 3 pt to drop? If handle moves then shim friction washers on lift control handle.
2022 EZ-GO ELITE...
CASE 580N BACKHOE (A65053)
CASE 580N BACKHOE...
ATS Mini Excavator ATS - ME18 (A66285)
ATS Mini Excavator...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
(INOP) 2002 CHEVROLET 3500 BUS (A59823)
(INOP) 2002...
Chery 21'x24' Double Carport (A64127)
Chery 21'x24'...
