Solar power anyone ?
   / Solar power anyone ? #41
The "powering of a well" Has been shown to be one of the biggest problems. A simple solution is a couple of totes.
An easy 300 gallon each solution usually $100 or less.
And as far as running fridges and a few lights a small backup generator does well.
Yeppers, that is why we have a small generator that hooks up the DR brush cutter engine. Water is a concern and there are hand pumps that work on deep wells but they are EXPENSIVE. We also put in an 80 gallon H20 heater which we can tap for water when needed. 80 gallons is a bunch of drinking water. The generator is really for the fridge, freezer and microwave though the generator will run our well pump.
Later,
Dan
   / Solar power anyone ? #42
Yeah, that federal "credit" was all the tax payers chipping in to pay for your so-called-green solar power system.
   / Solar power anyone ? #43
Yes, Thank you all! I feel bad for those people that don't have the right layout to have them. NYS made it a no brainer to get panels last year.
Well, given 50% of the folks in this country pay no federal income taxes, I assume we're only talking about the other 50%. Maybe complaining about that clear inequity ought to be the order of the day.
And unless we go to a complete no credits/no deductions type income tax, there are always going to be those that say "yeah, the taxpayers are paying for your (whatever)". I could make the same complaint about deductions for kids. We have none, so why should I pay for somebody else's kids. Or mortgage interest deductions....I don't have a mortgage......and so on.
The FACT is the feds DO put these things in the tax code, stupid as many of them are, and they ARE available to anyone that goes the route of qualifying for them, so if you have a problem with me taking advantage of a provision in the tax law, write your Congress Critter.
Otherwise, it sounds a whole lot like your grapes have soured.
   / Solar power anyone ? #45
You're absolutely right. If the government sees it in the best interest to aid/support/encourage then it should, but it should have a clear reason for doing so. If it wants to diversify the energy production of country great, but let's have these credits end after a given time period, so it takes work of the politicians to restore them. Is it in the national interest to have so many of the current credits? Absolutely not. But the government does have to "support" some industries at some times. It is a weapon that other governments can use, so we need to be able to handle it. Look into the mining of rare earths if your not familiar with one attack China carried out.
   / Solar power anyone ? #46
I thought this was about solar power ?
   / Solar power anyone ? #47
I don't have any info on the circuitry or what happens if a cloud passes over, for example.
It's a brand new product that may not be shipping yet.
SUNNY BOY 3000TL-US / 4000TL-US / 5000TL-US. SMA America, LLC
Total solar newb...
Would it be practical to have a grid tied solar array for daily use AND a small 3000 watt solar / battery system powering a dedicated receptacle for power outages? Not enough to run the whole house obviously, but you could run an extension cord - couple hours for the freezer, couple hours on the fridge, microwave / tv / lights as needed.
Appreciate the thread. Thanks all who has posted.
   / Solar power anyone ? #48
Total solar newb...
I think TnAndy has something like that set-up according to his posts. I guess the practicality depends on your overall needs (your power requirements, etc.) and how often and for how long do you lose power.
Personally, I find the combination of a grid-tied system coupled with a backup gas generator more practical. Something like a Honda EU2000 or larger would be useful for outages and portable power all the time. During an outage I need to run my well pump and water heater, at least enough to get by. I have a 6500 watt generator.
Since the generator is a totally separate unit with no dependency on any part of the solar system, it is going to work if something critical/single point of failure in the solar set-up fails.
Not to be morbid, but another consideration for those of us who are getting on in years, is what type of set-up could your widowed wife deal with or easily get assistance on?
Total solar newb...
That is what I have, though slightly larger.
I started with a grid tied, battery backup system that I expanded in stages from 2.1kw to 6kw (panel rating), with 5000w of inverter ( twin Outback 2500w that produce a true 240v ) power.....then added another 5kw of grid tie only using Enphase micro inverters.
I've been the route of using generator for grid down situations....got a 5,000w Coleman, and an 8,000w side of my Miller Bobcat welder......And as long as you're talking a short period ( like maybe up to a week or two ), that certainly is a cheaper way to go. Even then, fuel can become an issue for some folks ( I do store quite a bit of fuels in farm tanks )
But what I was looking for was more of a "what if the grid goes down for a long time, or maybe forever" situation, which is why I went solar......and given the rate structure HERE, and the tax credit, solar makes more sense to me....here....but that IS area dependent.
   / Solar power anyone ? #50
Total solar newb...
As part of the class I took earlier in the year, we toured a house that the instructor built. He built a bunch of homes in a development that where all of the homes had PC, solar water heaters, and passive solar design. The homes had small PV systems, 2-3KWH, and batteries wired for certain circuits in the house. The owner said there have been power outages and he had not noticed for a few hours because his main circuits were working off battery.
The solar was well integrated into the houses and the houses looked like normal subdivision houses except for the roof panels. The houses were quite expensive though.
Later,
Dan
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
2006 John Deere 650J LGP Crawler Tractor Dozer (A50322)
2006 John Deere...
2803 (A50460)
2803 (A50460)
2020 Kubota Z723KH 48in. Zero Turn Commercial Mower (A50324)
2020 Kubota Z723KH...
2025 Swict 60in. Bucket Skid Steer Attachment (A50322)
2025 Swict 60in...
