Backhoe Trying to put BH back on
/ Trying to put BH back on #41
Once removed, if my Backhoe is in the Sun, I have to take a wrench and loosen a fitting and bled off the pressure that has built-up due to the Hydraulic fluid expanding. I generally loosen a cylinder hose fitting and allow a couple of spoon fulls to leak out. Be sure to select a fitting that dosn't have pressure due some load placed upon it. Works every time. Fred
/ Trying to put BH back on #42
I have a New Holland TC45DA with a grapple on the bucket which I can't hook up due to pressure in the lines. The Parker fittings feel like they are welded closed. I just called my dealer and asked what I should do. They told me to crack the fittings to let a little fluid out which should relieve the pressure. They also said I would have to do this to both lines. They said it would just ooze and not squirt at me.
Hope this is helpful.
Guy
/ Trying to put BH back on #43
Go back and look at post #19, I bought this gadget and it is worth the price. Cracking fittings is pretty sloppy and a little dangerous. Contrary to post 41, by definition, they have pressure in them, if there were no pressure, the quick couplers would go back together easily. I used the rag and rubber hammer method until I bought George Waite's gadget.
/ Trying to put BH back on #44
Here's more info on the 'tool': Patent US7448406 - Hydraulic coupler pressure relief tool - Google Patents
/ Trying to put BH back on #45
Question: can't you depressurize those lines by just working the control lever with the engine off? I haven't tried disconnecting any of mine but it seems to dump the pressure in the hoses to the loader if I just work the loader control in all directions with the engine stopped.
/ Trying to put BH back on #46
Yes, but after an implement like a hoe or grapple needs to be connected back to the hydraulic system the fluid in the lines has expanded in volume from exposure to high temps, (exposure to hot sun) then the problem of the expanded fluid blocking the ball shut off from opening enough to reduce pressure inside the line occurs at point of connection; and one cannot overcome that issue without relieving the pressure manually, prior to hookup.
See the patent article description of how hydraulic systems function in the link in my post above- it gives a really good description of the problem.:thumbsup:
/ Trying to put BH back on #47
Post by Gil Case on 03-18-2013, 08:08 AM:
Here is a gadget you should have.
Simple Tool Solves Hydraulic Pressure Problems
A simple tool invented by George Waite makes releasing pressurized hydraulic couplers as easy as turning on a water faucet. Waite's Hydraulic Pressure Relief Tool works like pliers to grip the valve end. Turn a simple tap on one side of the pliers, and it slowly presses on the male fitting, gradually releasing pressure
Company: Waite's Tools
PO Box 66
City: ATWOOD
State: CO
Zip: 80722
Country: USA
Email: bramma@kci.net
Phone: 970 522 5696
/ Trying to put BH back on #48
The gadget only works on the male side, the female side (on the tractor) as you point out can be depressurized by moving control levers, but the male side (implement) is off the tractor, laying on the ground in the sun ergo the pressure build up.
/ Trying to put BH back on #49
Thanks for the explanation. I hadn't thought of that.
/ Trying to put BH back on #50
Some of us use both male and female on implements like grapples so we are forced to hook them up correctly. This tool is not so helpful if it doesn't have a way of relieving pressure on the female side.
I just keep a small ball peen hammer as well as a rag and a 3" piece of 3/8 brass rod in my tool box. The hammer taps the male tip through the rag and taps the brass rod which is positioned on the female nipple. No fuss. Works every time.
/ Trying to put BH back on #51
What I have been doing is this: I have both male and Female connectors on the grapple, when I disconnect, I push them together slowly without letting the collar engage and let the male and female "check balls" engage and disengage a couple of times so that they will "slobber" out some fluid, then let them come together and let the collar engage to hold them together. The Ideas is to puke out enough fluid so that there is a "deficit" of fluid in the lines, so that when it heats and expands, not much pressure will be built up in the lines.. I cannot say for 100% sure this will work on a really hot day in the sun, as that has not occured yet, but so far it has been working, and I have had no problems re-attaching.
James K0UA
/ Trying to put BH back on #52
Put some ice on the lines, or shoot them with Freon.
/ Trying to put BH back on #54
All my QDs are on my tractor with the male ends on the implement, including my grapple. I use colored coded tyraps, or for non aviation types........zip strips on the lines at the fittings to remember which line to connect were. I have only had a problem once in 7 years with pressure buildup in the line. The hammer trick cured that. Cheap, quick and easy.
hugs, Brandi
/ Trying to put BH back on #55
Hammer away, I did it for years, but it is not good for the QD and not safe either.
No editorial comment from me about spending $30,000 on a tractor and not willing to spend $30 for safety and convenience.
I have mentioned before, it sounds like I am shilling for Waite's Tools, but I have no connection with George Waite. I bought the tool on a recommendation from someone on this site, called Waite's, talked to the wife, got the tool and sent a check. Used it many times in the past two years. I guess in Texas it is hot all the time, here in NE if you take an implement off in the morning when it is 60 deg and want to put it back on in the afternoon when it is 85 deg you will have a problem. I also color code the line with red and black zip ties.
With that I am over and out of this thread.
2008 Ford E-450 Super Duty Ambulance (A64556)
2008 Ford E-450...
(2) 30 Yard Roll Off Dumpsters (A65579)
(2) 30 Yard Roll...
2019 VERMEER LP573XDT LOW PROFILE VACUUM TRAILER (A63276)
2019 VERMEER...
1986 Bumble Bee Fishing Boat (A66408)
1986 Bumble Bee...
Farmhand CG 3000 Tub Grinder / Bale Processor (A66408)
Farmhand CG 3000...
2015 TAKEUCHI TB280FR EXCAVATOR (A65053)
2015 TAKEUCHI...
