kubota backhoe cylinders leaking
/ kubota backhoe cylinders leaking #1
sdav62
garfield, ar
kubota 8200b
my kubota backhoe cylinders are leaking; do I need to rebuild them,or just replace seals,or are these procedures the same thing? my mechanical skills are good but time is a factor. do you think a professonal is best bet
/ kubota backhoe cylinders leaking #2
stretch them out and check the condition of the chrome rods and while they are stretched out give the rod/barrel a side to side pull and see if there is some slop in the gland area
This will give you an indication a pro is best if you have slop in gland and/or marks on the rod (new rod made)
otherwise repacking is pretty straight forward (clean, polish, clean, flush, clean, repack, clean, reassemble)
thanks !! wdchyd,I'lltry that . rods look pretty good what is the gland area sounds like the end of cylinder where seals are? If people knewwhat was really important in life tere would be a shortage of fishing poles
/ kubota backhoe cylinders leaking #5
Exactly........and Exactly.....(I'm heading to Lake-Ontario this weekend if that's any indication:thumbsup:)
213098 (A64276)
213098 (A64276)
(INOP) 2013 MACK ELITE LEU633 GARBAGE TRUCK (A62130)
(INOP) 2013 MACK...
John Deere 6125R (A64126)
John Deere 6125R...
case 370 glass door never installed (A61307)
case 370 glass...
Dexter trailer axles (A61567)
Dexter trailer...
17395SFL (A61568)
17395SFL (A61568)
