Slow tire leak - BX25D suggestions
   / Slow tire leak - BX25D suggestions #21
Hmmm... maybe I will have a little chat with my local Kubota dealer and let them know about the nuisance. I really don't expect them to do much however.
That would be the best place to start.
A good dealer should be willing to help you as they never know how much business they may gain or lose. We subsequently bought an M8540, L5030, L5740 and quite a few implements even though there is a Kubota dealer nearer to us.
Probably didn't word it right... so far my Kubota dealer has been great, especially parts counter guys! I just don't believe they would do something about a very slow leaking tire but I could be wrong. Might throw it in the truck this week and stop by and see what they recommend. Maybe I can tease them with a rear tire fill job?
   / Slow tire leak - BX25D suggestions #23
Sounds like you have good dealer. I didn't think my dealer would do anything either, but figured it was worth a shot, but this is a known problem so they did.
   / Slow tire leak - BX25D suggestions #24
The little BX front tires have very little volume. The rental companies around here always poly filled the little fronts because they are a constant problem.
You pay by the pound for poly filling, because of the small volume it does not take alot of poly to fill them.
Excuse my ignorance... but what's 'poly'?
   / Slow tire leak - BX25D suggestions #26
They call it foam filling or poly fill.
It is pumped in as a liquid they put a screw or bolt in the top of the tire so that the air will bleed out as the liquid is pumped in and rises.
It is pumped all the way full and set at the recomended pressure for the tire, it cures and becomes a solid with some give to it.
No more flats.
Call a tire shop that does forklift and industrial tires.
Okay problem solved... went to Les Schwab and they installed a tube. Total bill $29 for one. Let's see if the other side will ever need it. :confused3:
   / Slow tire leak - BX25D suggestions #28
I had several tubes put in and they all failed due it was thought to be the wheel moving relative to the tire. Had the last failed tube removed going back to tubeless then slimed it myself. Still had the slow leak so I might have done it wrong or used the wrong kind of slime. I bought a new tire and wheel combination with exactly the same slow leak problem. I gave up and settled for 3 trouble free wheels.
Hmmm... you are 'bursting' my bubble. :laughing:
   / Slow tire leak - BX25D suggestions #30
Sorry about that, today is beautiful clear sky low humidity the mood lightens. You'll be fine. They tubed the new wheel/tire and it has held up since last fall. Just have not been in 4WD with a loaded bucket on pavement.
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
New Kivel Walk Behind Pallet Forks (A50774)
New Kivel Walk...
2014 PETERBILT 367 (A50854)
2014 PETERBILT 367...
71065 (A49346)
71065 (A49346)
2006 INTERNATIONAL 4300 DT466 SBA 4X2 BUCKET TRUCK (A51406)
2006 INTERNATIONAL...
2015 KOMATSU PC170LC-10 EXCAVATOR (A50458)
2015 KOMATSU...
