kubota ignition key
/ kubota ignition key #1
locker
florence, al
kubota 3100
I lost my Kubota compact tractor key today and need toSTART it move my tractor what are my options.
/ kubota ignition key #2
You can hotwire it pretty easy if you have access behind the key (or can remove the keyswitch)
Easiest way it to just go to the dealer ASAP and get a new key.
/ kubota ignition key #4
If one of your neighbors has a Kubota, try his key until you get another one. It will probably start it. Just a thought.
/ kubota ignition key #5
Or....this is a long shot.. since the late model keys are all alike, perhaps someone here could scan their key, and post it as a pdf or jpg. with a ruler to scale it by, and you could saw and file one out of sheet steel. Like I said, a long shot, and a lot of work, but, it did come to mind as a possibility.
James K0UA
/ kubota ignition key #6
I went to the boy scout camp and forgot my key at home(2 hour drive). Another small key on my ring started the tractor and I left it run all day.
/ kubota ignition key #7
Where is your spare key? I got 2 keys with mine. :D
Ken
