Mowing Breaking BX Blade Bolts
/ Breaking BX Blade Bolts #1
logdog
The Thumb, Michigan
Kubota L3700SU & BX1860
I have a BX1860 with a 48 inch deck. It has been flawless the two previous mowing seasons but it is giving me fits this year. I have had four mower blade bolts shear off.
In the spring my wife took the deck in to the dealer to have the blades sharpened because I was out of town with work for awhile and couldnt get to it. The first bolt broke the first mowing after it came back. She was using it and said she didnt think she hit anything. I figured they didnt torque them right. They gave me a new bolt and washer. I replaced them and torqued all the blades to the manual spec.
A few weeks later another one (different blade) broke on me when I hit an ant hill. Replaced that and have broke two more under seemingly normal use. The heads just shear off the bolts!
I have looked and looked at the deck and dont see anything out of the ordinary. Nothing seems bent and the blades seem to spin as usual.
Has anybody else had any issues like this? The dealer hasnt heard of anything like this.
/ Breaking BX Blade Bolts #2
Sounds strange, I ground mine out on a stump and stalled the tractor and never snapped a bolt. Are all of them from the same place? I would suspect cheap imported bolts. Check the old bolts over visually and see if you notice any metallurgical issues or improper machining that would create a "Stress riser". Typically this area is the first area to fail when over torqued if there is a manufacturing flaw in this transition area, If no flaw is present, I have seen them "neck down" on the shank.
(I saw what 45,000 LBS on a hydrotorque does to a 2.5" nuclear grade bolt, necked it down to a 2.0" bolt outside the thread engagement area)
If its a cheap import, then I would say the grade of material used is not the one specified (Falsified grade stamping).
I would also check the one that has not broken if it came from the same store increasing the likelihood they are from the same batch number.
/ Breaking BX Blade Bolts #3
Are they the 12mm bolts with ~ 30mm heads? I have a BX1500 with 54" mower and havent had a problem in 2000 hrs - some of it pretty ruf. I broke one myself tho when I tightened it too tight with the impact wrench. Its head popped off just like you say. Your problem puzzles me. Its almost like the bolts are spinning tighter if the blade slips. But there should be a washer with internal hex that keys to the spindle to prevent that.
larry
All the replacement bolts have been OEM Kubota ones.
/ Breaking BX Blade Bolts #6
Have you replaced the washers on the deck? I think the set up of the washers is supposed to allow the blades to slip on the spindle if you hit something. The washers are cupped and I think they are called a bellville spring but I could be wrong. Here are the PDFs showing the spring plate the goes between the blade bolt and the blade.
View attachment A00701.pdfView attachment A01001.pdf
/ Breaking BX Blade Bolts #7
I could see the bolts breaking off if someone replaced the springs with washers. Just a thought.
/ Breaking BX Blade Bolts #8
Yep. Ive hit stuff the previous years and never had an issue
Is the thick washer with the internal hex stripped out? It should not be able to slip on the spindle -- that could wring the bolt tighter.
/ Breaking BX Blade Bolts #9
Could someone have weakened them with heat when removing them from the spindle?
/ Breaking BX Blade Bolts #10
Thats weird.
Ive eaten rebar with my MMM and never broke a bolt.
You sure torque is right?
Triple check that the blades arent hitting. Im wondering if there is a particularly rare situation where things line up to create contact.
The bolts arent bottoming out are they?
My washers do not have a hex, just a small curve.
I cant look at those pdfs on my phone. I will check them out later. But my deck doesnt have springs. The printout the dealer gave me doesnt show any either.
Thats weird.
I use the torque listed in the owners manual and I have a good Snapon wrench. It doesnt seem the bolts are bottoming out. They are the same length as the originals.
I still have to pull the deck back off (I hate doing that) but here are a couple pics of the carnage.
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=331158"/><img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=331159"/>
I figured out how to look at the pdfs and I see we were talking about the same thing.
/ Breaking BX Blade Bolts #17
My questions is how are you getting the broken bolt out of the spindle, I'd think that would be a *****. Mine does have a hex looking washer thing and I think I have two of the spring washers, but I also have a 60" deck.
/ Breaking BX Blade Bolts #18
I have over 600 hrs on my 48" mmm with the original bolts and washers. Have never had a problem and the blades have been removed every 25 - 35 hrs for sharpening. The washers are supposed to be installed with the cupped side toward the blade. Is it possible that one or both of the washers are not installed correctly? Also, is it the same spindle position that the bolt is breaking on? Maybe those washers need replaced.
/ Breaking BX Blade Bolts #19
Those cupped washers are the spring refered to. The washer with internal hex goes under them against the blade. This washer engages a hex on the end of the spindle and prevents any blade slippage from trying to rotate the bolt tighter. Evidently the 48" mmm does not employ this because they havnt had problems - but maybe you are having problems due to this lacked feature. Incremental slippage of your blade could continue tightening the bolt til it snapped. Maybe the whole thing has happened because your bolts are easier to turn than they were and easier than they are supposed to be. Maybe the dealer sprayed some good lube into the spindle threads and its effect lingers. Try a very spare application of moly antisieze just under your bolt head and back off~5% on your torque spec to ensure that the lower friction doesnt cause overtensioning. If indeed the bolt has been being tightened to failure by the slipping blade this should stop it.
/ Breaking BX Blade Bolts #20
I am not sure why you are breaking the bolts, other then the cupped washer might be out of spring shape. I use a impact on mine to remove and install. I dont torque them , just go by the feel and its been over 7 years for 3 blade bolts.
2012 Caterpillar Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
2012 Caterpillar...
2022 CATERPILLAR D8T HIGH TRACK CRAWLER DOZER (A65053)
2022 CATERPILLAR...
2017 Forest River Rockwood HW275 S/A Pop Up Camper Trailer (A64557)
2017 Forest River...
2004 JOHN DEERE 750C LT SERIES 11 CRAWLER DOZER (A65053)
2004 JOHN DEERE...
2016 Ford Escape AWD SUV (A64557)
2016 Ford Escape...
2006 JOHN DEERE 700J LT CRAWLER DOZER (A65053)
2006 JOHN DEERE...
