5v steel roofing
/ 5v steel roofing #1
randy41
Linden VA
you know the stuff. any reason not to just flip it over when one side gets rusty?
/ 5v steel roofing #2
The v's will hold the metal away from the supporting boards.
/ 5v steel roofing #3
yup... might be ok on a roof over a bale of hay or something... but i wouldn't do it on a barn.
/ 5v steel roofing
just a thought i had while (you guessed it) i was putting used 5v roofing on my little shed. you could put the screw in the v...right?
/ 5v steel roofing #5
sure.. you CAN screy it down.. it just won't set flat on the purloins and runners.. it therefore may not seal end to end, and may rattle in the wind.. etc. if it is a single long piece for the runs.. may make less of a difference.. especially if it is just a top cover, open sided structure on the cheap.
/ 5v steel roofing #6
I have seen commercial buildings done this way, but only on the walls. This was 26 guage steel.
Dave
2022 Behnke Trailer (A55973)
2022 Behnke...
John Deere 6110M (A60462)
John Deere 6110M...
New/Unused Sickle Bar Mower (A61166)
New/Unused Sickle...
CASE 588H ROUGH TERRAIN FORKLIFT (A62129)
CASE 588H ROUGH...
2025 LandHonor OBC-12-66W 66in Brush Cutter Skid Steer Attachment (A60352)
2025 LandHonor...
2013 GMC Sierra 1500 Crew Cab Pickup Truck (A61568)
2013 GMC Sierra...
