Kioti still working
/ Kioti still working #1
landedakioti
Gold Member
vermont
kubota L4060 hst
So they split the tractor to replace some seals . Replaced hydo pump and waiting for kioti to send a starter. They also checked the hydraulic pressures and said it was high then it was rated at. They hope a couple more weeks it should run like the dk 40 should witch will make me happy .
/ Kioti still working #2
Hope it works out well for you.
/ Kioti still working #3
May that Dark Cloud leave that tractor.
/ Kioti still working #4
You have been able to start it by jumping across the starter terminals. That to me means the starter is fine. Make sure they go through the whole start system including stop solenoid and ip before you take it back. Just a thought
/ Kioti still working #5
Who is doing the repairs for you this time?
/ Kioti still working #6
Hope you are on the home stretch this time and get the dang thing to where you can use it. I think you have more than earned it! CJ
I called them today and they will check the stop solenoid and the ip.
/ Kioti still working #8
Hope it works out for you Nathan, you sure took a lot of crap over/from that tractor. Its time you got some reliability from that machine. :thumbsup:
/ Kioti still working #9
I will ask again What dealer is doing repairs for you. Just would like to know
2003 Dodge Ram 4x4 Ext. Cab Pickup Truck (A59230)
2003 Dodge Ram 4x4...
2022 EZ-GO ELITE...
Bobcat T66 (A60462)
Bobcat T66 (A60462)
2016 Ford Fusion S Sedan (A59231)
2016 Ford Fusion S...
Merlo MF34.7 CS (A62177)
Merlo MF34.7 CS...
Towable Pipe Road Crossing Trailer (A63689)
Towable Pipe Road...
