Sfrankland
I had built a ripper a few weeks ago to test the design. It worked perfectly but I needed some extra offset to my thumb so I sold it and built a new one.
The ripper itself is 1/2" plate with 1/4" plate welded to either side. I cut my initials in it to act as plug welds. I added a weld on tooth so I can replace it as need be. The top plate is 9" wide and 1/2" thick, the extra width protects the pins I use on the quick coupler. The plate on the back is 1/4" and was bent using a 30 Ton press. I have used the thumb to roll around some 2-3 ton rocks and it held up perfectly. It does a great job ripping up stumps and rocks as well.
