Mowing rck54-22bx tension spring
/ rck54-22bx tension spring #1
parkwatydog
Murrysville, pa
Kubota bx22
I recently had to repair one of the mower blades on my rck54-22bx deck. I am really struggling to restore the tension pulley and the tension spring as pulling the spring with the belt in place seems to require the strength of a super-hero. Am I missing some trick or some tool or is it just a matter of brute strength? Thanks in advance.
/ rck54-22bx tension spring #2
Oh yeah that's no fun! I did this on my 60" a couple of years back and I tried a bunch of different ideas like putting the spring on with the belt off and using a large pry bar to retract the tension pulley enough to slip the belt on. In the end I seem to recall just using a large screw driver to stretch the spring and catch it in the hole. I remember feeling kind of lucky when it caught after only a few tries. Maybe someone else has worked out a more fool proof method.
Good luck!
Sent from my iPad using TractorByNet
/ rck54-22bx tension spring #3
Hopefully I can articulate this so it is understandable. One of the best tools I have seen for this was a one half inch steel bar approximately three foot long with a T handle on one end. The other end had U approximately two inches long. The short side of the U was bent out to about a thirty degree angle.
The individual could remove or install belts quickly. The U allowed the tool to be positioned in such a way on the retention post to allow the bent side to be twisted forcing the spring from the post, yet retaining control.
/ rck54-22bx tension spring #4
Oh, yeah. Took my spring off for winter storage a few years ago - never again. About got a hernia trying to put it back on. Had me and the wife working on it at one point. I believe I used a combination of a ratchet strap and a come-along. I think the come-along worked in the end. Trying to remember, but I think I used the ratchet strap to secure the deck to an immovable object, then the come along to get the spring on. It was a real b-i-t-c-h.
2017 Case CX145D (A60462)
2017 Case CX145D...
60in Bucket Skid Steer Attachment (A61567)
60in Bucket Skid...
(10) 2" X 3" X 98" TUBING, (8) 1 1/2" X 3" X 82" (A64280)
(10) 2" X 3" X 98"...
2017 Versatile 260 (A64126)
2017 Versatile 260...
2018 Navigator RT-6500 6,500lb Piggyback Forklift (A61567)
2018 Navigator...
1992 Norris Long Basket Trailer (A60460)
1992 Norris Long...
