Rotary Cutter What brand of cutter is this ?
   / What brand of cutter is this ? #1
saluda
Bessemer City, N.C.
Ford 3910
I need to know what brand of rotary cutter this is and if this is worth the cost to repair, Deck needs welding, PTO shaft, Bearing in Tail wheel, new blades.
Thanks for your Help
   / What brand of cutter is this ? #2
Welcome to TBN. Don't know what brand cutter that is. I have seen those back in the day because I remember those brackets around gearbox. What color paint does cutter have underneath red that would be another clue. Yellow-Woods/Red- Bushhog brand etc. As far as bearings,pto shaft,blades those can be "matched" if need be. Looks to me like its worth repairing. I'd also drain or suck out if no plug gearbox oil and replace with fresh 80/90 wt. Also don't forget your pto shaft safety covers if you don't have any (can't tell by pic). Hope it helped.
Boone
   / What brand of cutter is this ? #3
The tail wheel and rear a-arm looks like an Agritech But the gearbox and bracing is way different. You may have trouble if you ever need another(gearbox) but it looks like a well built unit. A coat of paint and check the lube and you will be ready to go.I don't see anything that needs welding.
2023 Top Air ATV 200 Gallon Pull Type Sprayer with 30ft Booms (A55314)
2023 Top Air ATV...
2024 Timpte 40ft Hopper (A55314)
2024 Timpte 40ft...
2005 EZ-GO Utility Cart (A55851)
2005 EZ-GO Utility...
2025 Platform Safety Basket Attachment (A53421)
2025 Platform...
20 ft. Shipping Container (A53117)
20 ft. Shipping...
2024 John Deere 6110M MFWD Tractor (A53485)
2024 John Deere...
