Duramax problems! No parts for 2 months
/ Duramax problems! No parts for 2 months #61
Not at all. Call me a liar and you will have a problem you dont want!
I have stated from day one that the 4.3 blew up on my Blazer with less than 30K on it. Go back and reread my many post on the subject. I had to fight to get it covered under warranty, 3yr 36k at that time, with a lawyer. It took about 3 months and to add insult to injury GM's policy was no loaner for anyone under 21 which I was at the time. So I was good enough to sell a $30,000 truck to but not good enough to give a loaner to. Total BS.
Go back and reread before you make accusations of me lieing or falsifying stories. I have no need to.
Chris
Off topic, sorry...... PM me a pic of your 861?
/ Duramax problems! No parts for 2 months #62
It was sold last month when I lost my primary job. I had it listed as 861 at work. We used it to pull the airplane in and out of the hanger. I had no need for it at home since I have my Jinma and another guy at the airport wanted it to use for the same purpose so I let it go.
It was painted in Ford Blue and looked like a Ford 3000. I will look for a pic in my files.
Chris
/ Duramax problems! No parts for 2 months #63
I have an 2011 Chevy 2500 HD diesel it has 104 000 km on it. Last week the light came on and said service now! So we did so and the truck been there since last Wednesday. after 4 days they find the problem and order the part....the part is not available in North America.....out of stock!! The def part that we needs cost 300 bucks and 400 bucks of labour and its not under warranty. And worst of all the part won't be in till the end of September! So two month with our my truck the dealer doesn't want to help me don't want to lend a truck what else are my options?
Thanks
What part is the dealer saying you need? 2 months wait for an 11 part?? Is it a sensor that is giving a false reading causing the DEF to go into stage 2 limp mode. Give me more info. Part # would be a great help.
It's a heater in the reservoir and they need to change the whole assembly and they have no more stock and I think they must be working on fixing the part because there's so mAny problems with this def system
/ Duramax problems! No parts for 2 months #65
Chris
Grow up..I didn't call you anything...Your stories just get better and better....Threaten me all you want..I can more than handle it.
/ Duramax problems! No parts for 2 months #66
I would be great if you can get me the part # the dealer says it needs (they tend to change w yr). I will do some digging in the hold up. I will PM you.
/ Duramax problems! No parts for 2 months #67
Back on subject--There are a ton of fleet service dealers that probably have the needed part. Dealers swap parts all the time, all it takes is the right dealer with the ambition to locate the part..It is possible the part doesn't exist today, but I highly doubt it.
Might cost you a flatbed trip, but it might be worth it...
/ Duramax problems! No parts for 2 months #68
I am all grown up and don't make threats. I will not be called a liar when there is documentation proving my case.
Go back and reread any of my post on the subject. I did a 30 second search using my screen name "diamondpilot" and "blazer 4.3" or "blazzer 4.3". Stupid spell check. I found post dating back better than 3 years that verify what I have said.
Please do some research and post back your results with a apology if you are man enough. I know I would before I called someone out and if I am wrong, which I am many times, I call myself on it.
Chris
Well the dealer magically found the part in Montreal an hour of where a live after they said they were sure they dint have any in North America!! Last time we ever by something there or bring something in for service
/ Duramax problems! No parts for 2 months #70
Andre, we bring our gm's to Roy's Chevrolet near Alexandria. An hours drive for us..... Not sure if that helps you.
2023 VOLVO ECR25 ELECTRIC EXCAVATOR (A60429)
2023 VOLVO ECR25...
2011 KENWORTH T370 (INOPERABLE) (A58214)
2011 KENWORTH T370...
Giyi-D39 QA Trencher (A60463)
Giyi-D39 QA...
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
2016 MACK CXU613 MID-ROOF SLEEPER (A58214)
2016 MACK CXU613...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
