Cab Owners - How well does your A/C work?
/ Cab Owners - How well does your A/C work? #21
Mf 1660 with tinted windows. The a/c works better than the one in a truck, the tint helps out alot.
/ Cab Owners - How well does your A/C work? #23
Thats weird.... i replied to this post awhile ago, and the post disappeared.
Ill try again
I have a 2011 Kioti DK45HST cab and used the a/s yesterday in 95-97 F heat and it was wonderfully cold in the cab. Had to turn the temp and fan down as i was getting chilled.
Also, the heat works great in winter snow plowing.
Best investment i made in a long time.
EDIT: i wasnt nuts....i posted to another copy of this post in a different forum.my bad
/ Cab Owners - How well does your A/C work? #24
Kubota L4240 works great in 90-100* heat. At times it is very humid here. By the times I start it and move it 5' the evaporator drain is dripping.
Ill try again
Sorry about that. I realized I should have posted this in the general owning/operating forum, so I cross-posted. Thanks for your response. A Kioti DK50SE HST Cab is one of the tractors I'm considering, so your response is helpful.
/ Cab Owners - How well does your A/C work? #26
I used a hybrid metallic film (35%), as suggested by someone here on tbn.
/ Cab Owners - How well does your A/C work? #28
My 3540 cab works great. It can get so cold that I can hang meat in it!
/ Cab Owners - How well does your A/C work? #29
No hijack, but that's a nice looking ride. :thumbsup: Where'd you get that done?
/ Cab Owners - How well does your A/C work? #31
/ Cab Owners - How well does your A/C work? #33
I have no problems at all with night time visibility, i do have great cab lights though. The biggest drawback that i have found is that it is difficult to see in from the outside, such as giving hand signals to someone driving a hay trailer and you want them to pull up a little bit. I don't use it too much at night....mostly haying cows and occasionally some bush hogging.
