Cab Owners - How well does your A/C work?
/ Cab Owners - How well does your A/C work? #21
Mf 1660 with tinted windows. The a/c works better than the one in a truck, the tint helps out alot.
/ Cab Owners - How well does your A/C work? #23
Thats weird.... i replied to this post awhile ago, and the post disappeared.
Ill try again
I have a 2011 Kioti DK45HST cab and used the a/s yesterday in 95-97 F heat and it was wonderfully cold in the cab. Had to turn the temp and fan down as i was getting chilled.
Also, the heat works great in winter snow plowing.
Best investment i made in a long time.
EDIT: i wasnt nuts....i posted to another copy of this post in a different forum.my bad
/ Cab Owners - How well does your A/C work? #24
Kubota L4240 works great in 90-100* heat. At times it is very humid here. By the times I start it and move it 5' the evaporator drain is dripping.
Ill try again
Sorry about that. I realized I should have posted this in the general owning/operating forum, so I cross-posted. Thanks for your response. A Kioti DK50SE HST Cab is one of the tractors I'm considering, so your response is helpful.
/ Cab Owners - How well does your A/C work? #26
I used a hybrid metallic film (35%), as suggested by someone here on tbn.
/ Cab Owners - How well does your A/C work? #28
My 3540 cab works great. It can get so cold that I can hang meat in it!
/ Cab Owners - How well does your A/C work? #29
No hijack, but that's a nice looking ride. :thumbsup: Where'd you get that done?
/ Cab Owners - How well does your A/C work? #31
/ Cab Owners - How well does your A/C work? #33
I have no problems at all with night time visibility, i do have great cab lights though. The biggest drawback that i have found is that it is difficult to see in from the outside, such as giving hand signals to someone driving a hay trailer and you want them to pull up a little bit. I don't use it too much at night....mostly haying cows and occasionally some bush hogging.
UNUSED KJ 20' BI PARTING GALVANIZED GATE (A62131)
UNUSED KJ 20' BI...
Trailmobile Van Trailer (A63118)
Trailmobile Van...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
DEERE CLIMBER (A62131)
8064 (A61166)
8064 (A61166)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
