turf tires and rims
/ turf tires and rims #1
neilly2
Bucks County PA
Kubota L285 with V1500A engine
I have an L285 with ag tires. I'd like to get a set of turf tires as well, but the Kubota dealer says they're not available.
Does any one have a source for aftermarket rims?
/ turf tires and rims #2
I will try to help. What size tires?
Well, I'm not sure how to answer.... the sizes of the tires currently on it are:
Front 5.00-15
Rear 11.2-24
I'm too desparate to be embarrassed about saying I don't know how to size new turf tires or rims for that matter. The new yard is starting to come in and I don't want to mow it with ag tires on it.
Any help is appreciated.
/ turf tires and rims #4
The 112-24 is definitely doable in a Firestone Farm Service Diamond. They are about $250 each. The 500-15 is proving to be a bit more of a challenge. I can't find anything, except an implement tire and R1 (which you already have) in that size. Let me do some more research and I will get back.
/ turf tires and rims #5
Front 5.00-15
Rear 11.2-24
Could you just put on 15" street tires off of a car/truck until you find a suitable tractor tire? They wouldn't be very aggresive, and might work in a pinch.
/ turf tires and rims #6
I know this is an old thread, but I have 185/75R15 on the front. Its a used small car tire but it works and was $25 mounted. Mine is 2WD, so as long as it fits it will work. Width is your enemy because the rims are sooo narrow. Also the steering components will rub a wider tire.
/ turf tires and rims #7
you and I are exactly the same. got the same prob. I have the same trac. tire size and all. have you found out anything new?
/ turf tires and rims #8
Also, if it helps, Tractordata lists 11.2-24, but I have 12.4-24 on rear, and they work fine, try searching 12.4-24 r-3 tires.
I found these, 13.6-24 Titan Torc Trac TL R-3 tires, 4 ply. No idea price, and I can't swear they will fit.
Nvm, found it: Carlisle 11.2-24 Turf Pro 6-ply, $385 each, Miller Tire (online store, don't know how to link from phone).
I did some search on fronts, 5.00-15 tires=27.3" tall, and wow, 5" wide...
205/75r15 trailer tires=27.1" tall, and 8.03" wide, some they may or may not physically fit your steer components, and may or may not seat on your rims, but height is perfect.
Is there a reason 5.00-15 3-ribs wont work for you, mine don't damage lawm unless I turn sharp, but turfs will too
/ turf tires and rims #9
Yes... they tear up the yard pretty good. but I am checking on some here locally. but don't no yet. Thanks Paul H.
(2) RIMS FOR 10 LUG HUBS (A64278)
(2) RIMS FOR 10...
BOUROUGHS 300 GALLON SPRAYER (A64278)
BOUROUGHS 300...
2023 JOHN DEERE 450P LGP CRAWLER DOZER (A65053)
2023 JOHN DEERE...
46192SFL (A64557)
46192SFL (A64557)
2007 FREIGHTLINER COLUMBIA TANDEM AXLE 6 X 4 TRUCK TRACTOR (A67147)
2007 FREIGHTLINER...
2025 Hydraulic IRANCH Tilt Bucket Mini Excavator Attachment (A64553)
2025 Hydraulic...
