Wiring FIMCO 12V 40 Gallon 3 pt Sprayer L3940
   / Wiring FIMCO 12V 40 Gallon 3 pt Sprayer L3940 #1
Maibox
Winona, MN
Kubota L3940; 1942 Farmall H (for sale)
I have about 3-4 acres of pasture and was in need of a very basic sprayer. I picked up a FIMCO 40 gallon 3pt sprayer on sale: Fimco 40 Gal. 3-Point Sprayer - Mills Fleet Farm
It comes with an 8 ft lead wire w/ switch to connect to the battery to power it. I don't think 8' is going to be enough. I would have thought the L3940 would have connector somewhere in back, but if it does, I can't find it and some time on this site and Google have yielded no help. I am looking for ideas on how to wire the sprayer short of getting a longer wire and running it to the battery. Caveat--I am a complete novice and I don't know a single person that would call me "handy" but I can follow instructions (which I always read), so I got that going for me.
Thanks in advance.
   / Wiring FIMCO 12V 40 Gallon 3 pt Sprayer L3940 #2
On my L3400 (when I had it).. I found a work light lead on the back and wired to that with a waterproof 2 prong trailer connector. My tractor did not have the worklight, but it is just a kit, and a there is a "bullet" connector wrapped up with tape in the wiring harness so it is worklight "ready" . It is hot with 12 volts when the key is on and fused for 5 amps. My Fimco sprayer drew about 2 amps. Worked good and I could reach the supplied sprayer on/off switch from the seat.
James K0UA
   / Wiring FIMCO 12V 40 Gallon 3 pt Sprayer L3940 #3
I mounted and wired a 7-way RV plug to the back of my L3940. The plug is full function, including constant 12VDC, which could power a sprayer (okay not brake lights or trailer brakes). Yes, I had to run a wire, but only to the starter, as the battery wire is already mounted to the starter. Install fuse, follow wiring harness to tail lights, and you are good to go. Philip.
   / Wiring FIMCO 12V 40 Gallon 3 pt Sprayer L3940 #4
That is waaay to professional looking:)
   / Wiring FIMCO 12V 40 Gallon 3 pt Sprayer L3940 #6
I have always run sprayers like this on my ATV's from a cigarette receptacle. I cut the wires on the sprayer and then splice a male cigarette receptacle on to it.
   / Wiring FIMCO 12V 40 Gallon 3 pt Sprayer L3940 #7
Is the small black box with the yellow wire running into/out of it the fuse?
yep that would be an ATC type inline fuseholder.
   / Wiring FIMCO 12V 40 Gallon 3 pt Sprayer L3940 #8
Thanks. Do some volunteer work around here for schools or sports clubs. Sometimes I need to put 2 or 3 implements on my main trailer and tow them to the spot of work with the tractor. Makes it nice being able to hook up the 7-way from the trailer to tractor. Even charges the break away battery.
Maibox, All these parts can be picked up at NAPA, or a local automotive shop. This would be a good project for a starter diy'er, fairly easy job. Need ATC in line fuse, wire terminal ends, wire, wire splice taps, bracket and plug, tie wraps, wire loom, drill and tap, and a few hours on a Saturday morning. If you need more detailed pics, just let me know.
Philip.
Philip.
Thanks Phillip. About the only thing I'm not sure about is how to tie the wire into the starter wire--I assume you just spliced at that location and then ran it back?
   / Wiring FIMCO 12V 40 Gallon 3 pt Sprayer L3940 #10
No. Disconnect negavtive cable from battery. Find positive wire from battery where it connects to starter (see where yellow wire runs under black cap). Remove this nut, add new end connector and fuse holder here. Philip.
Philip--going to give this a try today. Heading out in a bit to gather the parts. If you listen carefully around 11 am CT you might hear some cursing coming from Minnesota...:laughing:
   / Wiring FIMCO 12V 40 Gallon 3 pt Sprayer L3940 #12
I hope I hear some spraying from Minesota! Good luck. Philip.
Well, after running around collecting parts for the better part of the morning (including getting a new 18V cordless drill :)), I assembled the sprayer and then began the project. I was only going to hook up a 12v plug but I couldn't find any with good mounting method that I liked so I decided to follow in Philips footsteps. What sealed it was I found a 7 pin connector with a nice mounting bracket and an adapter that had a 12V plug (something like this Hopkins Multi-Tow Trailer Connector Adapter - 7-Way to 5-Wire Flat/4-Wire Flat and 12-V Power Socket Hopkins Wiring HM47675). I'm only running the one wire for now--I'm guessing I'm going to regret that decision.
I got as far as connecting to the starter when it became clear that my 12mm socket wouldn't fit in the in space and I didn't have a 12mm wrench (11mm and 13mm, of course). So back to town to get the wrench. I got the wire run back to the rear and then decided to call it quits. I wasn't sure where to mount the bracket, but in looking at Philips pictures, again, I see now where he mounted it. It's going to be a long week at work so I may not get back to it until next weekend.
   / Wiring FIMCO 12V 40 Gallon 3 pt Sprayer L3940 #14
Good work, almost done! Remember to unhook the negative connector from the battery before you do any electrical work, and it is also the last one to hook back up once you are done with all your electrical work. I believe I used #12 (maybe #10?) screws to attach my bracket to ROPS, so get a couple taps, tap handle, and correct size tap drill. Make sure you get all screw parts the same, either corse or fine. Let me know if you need any more pictures. Philip.
Appreciate the help Philip.
How long of screws did you use? I got 10-24, 1/2 inch. Got the tap as well. Look like the bit size is 25, which appears to translate to 5/32" in fractional. Never used a tap before, but watched a couple of YouTube videos. Any pointers?
Thanks again.
   / Wiring FIMCO 12V 40 Gallon 3 pt Sprayer L3940 #17
Just need screws long enough so threads go all the way through rops. Rops thickness + bracket thickness should be less than 1/2", so I believe you would be fine, just double check. I would use a #25 bit, but 5/32" is very close, only .006 larger. I would not use the combo bit, you drill at over 1000 rpm, and you tap 10 rpm, keep it simple. When you start tapping, when you feel resistance, back the tap out at least 1/2 turn. This is called breaking the chip. If you get too much resistance, and do not clear the chips, you will break the tap, and these are no fun to remove. Use a little lubricant on the tap, go slow, bring the tap all the way out to break or clean chips, and you will do fine. Philip.
Do you recommend hand-tapping vs. using a tapping bit and drill?
   / Wiring FIMCO 12V 40 Gallon 3 pt Sprayer L3940 #19
I only hand tap. With your experience, I strongly suggest hand tapping too. Philip.
   / Wiring FIMCO 12V 40 Gallon 3 pt Sprayer L3940 #20
Just get a little T handle tap wrench. Make sure the handle can slide from side to side for close quarters work in needed. Use the handle in the center position if possible, you do not want to apply a heavy side load to the tap. Philip.
(APPROX. 20) 4' X...
Massey Ferguson 4710 (A60462)
Massey Ferguson...
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
2020 Peterbilt 367 Weldco Hydra-Lift WHL45TC100 45 Ton Tri Axle Telescopic Crane Truck (A55973)
2020 Peterbilt 367...
EXCAVATOR QUICK DISCONNECT (A58214)
EXCAVATOR QUICK...
WATER TRAILER (A58214)
