60gal compressor mod
/ 60gal compressor mod #1
ericher69
Ontario Canada
2008 Kubota b2920
My 60gal 6.5hp compressor is in a tight corner therefore I had a hose made to replace the stock 1/4" pipe plug.
As you can see from the pic a ball valve is at the end of the 36" hose with the original 1/4" pipe plug as a redundant safety.
Should not have any issues now changing the oil twice yearly!
/ 60gal compressor mod #4
This also let's the oil flow into a container instead of down the machine side.
/ 60gal compressor mod #5
This is the main reason I want to do the mod, the easier the oil is to change the more likely that I'll keep up with it.
2013 Ford F-350 (A60462)
2013 Ford F-350...
Toro Zero Turn Lawn Mower (A56859)
Toro Zero Turn...
Oxy-acetylene Torch and Regulator Rig (A61307)
Oxy-acetylene...
2017 John Deere 6120E (A53317)
2017 John Deere...
2007 JLG E400 AJP TELESCOPIC/SCISSORING MANLIFT (A52707)
2007 JLG E400 AJP...
KJ K0720 7'x20' Metal Gate (Deep) (A60463)
KJ K0720 7'x20'...
