L4240 upgrades
/ L4240 upgrades #21
Sounds logical. I was curious because the non adjustable link has three pin holes while the adjustable one only has two.
There are some out there that have the 3 pin locations on the stationary link and only have 1 pin location on the adjustable link.
I almost always try to match the stationary link clevis for the side links that I build. ;)
/ L4240 upgrades
I made the 12 volt power port so it is on all the time, before it would only work with the key on. Now I can hook a battery maintainer through it.
I removed the 20 amp fuse from the fuse box that said "cigar lighter." I got a fuse holder and put the 20 amp fuse in it. I used a scotch lock connector and tapped into the yellow wire(in the back of the fuse box) that went into the cigar lighter hole in the fuse box and the one side of the fuse holder. I used another scotch lock connector to tap into the big red main wire going into the back fuse box and the other side of the fuse holder.
Here is a pic of the back of the fuse box.
/ L4240 upgrades
I forgot, I rearranged the hoses on the TNT.
/ L4240 upgrades
I added a LED light strip. On with the headlights and flashes the 4 ways.
/ L4240 upgrades
I added a battery mat.
/ L4240 upgrades
I got the step linexed. It feels some much more grippy now. It is a inexpensive upgrade and well worth the money.
/ L4240 upgrades #29
I like the linex, but am looking at having my son fabricate a better step with a wider platform, would love to have a platform like on our M8540.
/ L4240 upgrades
Thanks. Will the step of a 8540 fit on a grand l?
/ L4240 upgrades #31
No, totally different design, you might be able to see it in this photo, I don't have a picture of it from a good angle.
/ L4240 upgrades
You would be best off building one like you said.
/ L4240 upgrades #33
Yeah, I am going to get together with my son or brother and see if we can come up with something.
/ L4240 upgrades #34
Nice job on the step, it doesn't take long to ware off that factory gray paint, looks good i'll bet it feels good too. What is linexed some sort of rugged powder coat? Is your rear tire valve stem on the outside?
/ L4240 upgrades
Linex is a spray on truck bed coating.
It does feel good, it makes a uncoated step feel slippery in comparison. I was going to do it with a can of duplicolor truck bed coating but it is smoother and it took it while the truck bed was being done.
Yes the rear valve stem is on the outside, I guess it would be best to have it on the inside.
/ L4240 upgrades #36
My stem is on the inside and I wish it was on the outside, I don't see the point to have it on the inside, the dealer said that is how they come on the inside??
/ L4240 upgrades
It is probably more protected on the inside but it would be harder to check the air pressure.
This is how they come
/ L4240 upgrades #38
My tires the way they were mounted on the rims the valve stem is on the inside once mounted on the tractor.
/ L4240 upgrades #39
You don't really get a choice on inside or outside. It's determined by the rear wheel width you want. On the Ag tire/wheels if your stems are on the outside then you're wheels are set to the widest position. If they are on the inside then they are set to one of the narrow positions. I would suspect that the R4s are the same.
/ L4240 upgrades
I looked the valve stem can not be turned to the inside on the 4240.
Sent from my Samsung SPH-L710 using TractorByNet
Kuhn FC400RG (A60462)
2018 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
CATERPILLAR D1 CRAWLER DOZER (A65053)
CATERPILLAR D1...
2020 John Deere 6120M (A62180)
2020 John Deere...
2025 IREV Electric Scooter (A64194)
2025 IREV Electric...
2015 Ford Mustang Convertible Coupe (A61574)
2015 Ford Mustang...
