CK20S transmission slipping
/ CK20S transmission slipping #1
Jervis
Member
New Glasgow, NS
2012 Massey Ferguson 1648 Dyna, 2008 Kioti CK20s HST, 2012 Kubota B2630 w BH77
I have a 2008 ck20s and have noticed that when going into a pile to get a load in the bucket if my tires have good traction the transmission will slip instead of bogging down the tractor. We had a little kubota before this tractor and it would bog the motor down before it would ever slip.
I only have a few posts in this forum so i dont want people to think i go into a pile so hard that i bog down the tractor everytime i just noticed this issue one day when the ground was a little harder then i thought and became a concern.
Is this just a pressure issue and can be addressed or is something wrong?
/ CK20S transmission slipping #2
Sounds like the classic symptom of a worn clutch to me. Did you or a previous owner ride the clutch to modulate speed? The clutch is not covered by warranty for this reason; you can burn one out in a couple days if you try. The bad news is that clutch replacement is a big job on a tractor; the tractor needs to be split and any loader removed first.
/ CK20S transmission slipping #3
I have a 2008 also with 318 hrs. and have been working with some huge stumps this week. Mine will spin the tires or kill the engine if I forget to throttle up all the way. Not sure what to say on yours. Mine has the easy on the lawn tires though.
We have owned the tractor since new it's always done it about 500 hours on it! I just joined here so thought I'd ask the question dealer said it was normal! What made me think it was pressure issue was it gets better if you rev it up
Does any one else have this issue?
/ CK20S transmission slipping #6
+1
The CK 20s is the gear model.
Sounds like a slipping clutch to me.
/ CK20S transmission slipping #7
If it is a gear drive as Vince says, then it could be just a simple clutch adjustment needed. Consult your manual for the amount of free play at top of clutch before it disengages. If the clutch is properly adjusted and it still slips, time for a new clutch. Continued running with a badly worn clutch will likely damage the pressure plate and flywheel which will be some added dollars to the repair.
I'm sorry guys I forgot to say its a ck20s hst
/ CK20S transmission slipping #10
My will bog down, it will not spin the tires which I see as something wrong, at 22hp the tractor should spin the tires if the ground is soft/hard enough, especially with the industrial tires.
I have noticed yesterday that if you put the front buck on the ground in full dump position and try to lift the tractor's front end off the ground with the loader it struggles to do so, it should lift the front end with no problem.
Mine doesnt bog down, it will just stop moving and the transmission will whine. I obviously let off when this happens but I would like to know if anyone else had this issue and what they have done about it. The dealership says I am pushing the machine too hard but I think it should bog the engine down before slipping.
I dont think mine struggles to lift the front end up so to speak but it takes a little while.
/ CK20S transmission slipping #12
What RPM's are u running? Are u in low range? Ck20s should have no problem lifting the tractor of the ground as long as you have enough rpm. The ck20 only has 7.66 gpm of pump flow though a single pump. This makes the hydraulic week at low rpm. Tires should also spin in low range with rpm. Good luck.
Please don't take this the wrong way, I would like to keep this on topic to find anyone that has experienced this transmission slipping problem before.
/ CK20S transmission slipping #14
What RPM are you running?
What range do you use?
Do you smell something similar to burning brakes?
Does the engine bog at all when it does this?
/ CK20S transmission slipping #15
Trying to push a rock or big pile. Mine will lug the engine down and stall it. I haven't ever had it slip.
It will happen with any rpm but seems to be worse down low.
It happens in low range I never tried in high.
I don't smell anything burning but I let off as soon as it begins to slip. Transmission starts to develop a significant whine when it begins to slip.
Engine may bog a little but I wouldn't say significantly. Slipping issue progressively gets worse as the tractor is worked (fluid gets hotter).
/ CK20S transmission slipping #17
My experience with my CK30 was that in mid range, digging into a pile, the engine would bog down and I could stall it if I kept going. If I pushed into a pile as hard as I could, the transmission would "slip" as you're describing it and the engine would not bog down at all, it was only when I got the combination of pushing into the pile while raising the bucket and curling the bucket that I would bog the engine down and I used this as an indication I was getting a good full bucket of material. That was also the only technique that let me break out of the pile with that loader.
The loader on my DK45 is a beast and I don't need to push in, curl and lift at the same time to be able to break out of the pile with a full bucket. It will still bog down a little, but will also "slip" if I just keep pushing into the pile.
Are your tires loaded or do you have lots of ballast? That tractor is heavy enough that it won't necessarily run out of traction and spin the wheels. The effect you'll get is it simply stops moving and the transmission "slips". My JD could sit and spin all 4 tires all day long, but neither of my Kiotis will spin the tires, even in low, on anything other than snow or mud.
The back tires are loaded and what you mentioned describes the exact symptoms I am experiencing. I had a Kubota before this tractor and like your JD it would either spin the tires or bog the engine down. I am a little concerned about this issue as anything slipping accelerates wear and generates unwanted heat.
/ CK20S transmission slipping #19
Well, I can't say I know exactly what's going on in the HST, but I don't think this is something to be concerned about. When the tractor stops, I just drop a gear, once I'm in low and it's stopped, I'm either spinning the tires stuck in the mud (or snow) or I'm not going to move whatever it is I'm trying to push (or pull, like a box blade), so I stop. I'm sure it goes without saying, but HST is counter intuitive to use, the harder you push the pedal, the less power you get. You need to back off the pedal instead of pushing harder.
/ CK20S transmission slipping #20
I am not too familiar with how HST works other than to say I have one in my Kubota and it will stall the engine in high and spin the tires if in low or med. range. I do think that since they are hydraulic, they should have a relieve valve and it sounds like yours might be by-passing at too low of a pressure. This could be by design but I doubt that a tractor is designed to not be able to spin the tires. I have no idea how you would raise the pressures, but your dealer should be able to check it for correct setting and adjust as necessary.
(30) 3"x9' Steel Posts (A66408)
(30) 3"x9' Steel...
2019 Chevrolet Silverado 2500 Pickup Truck, VIN # 1GC1KREG4KF129755 (A65563)
2019 Chevrolet...
Landhonor Mini Skidsteer Combination Bucket (A66408)
Landhonor Mini...
2022 SANY SY35U EXCAVATOR (A63276)
2022 SANY SY35U...
2008 Ledwell LW48HTHT2 48ft. 40 Ton Hydratail T/A Step Deck Trailer (A64194)
2008 Ledwell...
New/Unused ATS Plasma Cutter (A65583)
New/Unused ATS...
