345 hydro will only move half speed-
/ 345 hydro will only move half speed- #1
purpony
CT
JD 2440/JD 3020/JD 314/JD 345/JD 850/JD 2320
My 345 hydro mower will only move half speed.... not sure where to start. Checked fluid level and thats fine. Should i do a filter and fluid change?
/ 345 hydro will only move half speed- #2
I would look at the linkage underneath to see if something is loose or bent. Same problem for forward and reverse?
I am not familiar with that mower but some have a brake interlock linkage that could be involved with the problem.
Likely you will need to remove some sheet metal to see how all this works.
The filter might be clogged but not if the problem started all at once.
2015 Ford F-350 4x4 Ext. Cab Pickup Truck (A61573)
2015 Ford F-350...
Bobcat T66 (A60462)
Bobcat T66 (A60462)
2005 Ford Explorer XLT 4x4 (A62613)
2005 Ford Explorer...
2015 INTERNATIONAL PROSTAR (INOPERABLE) (A63569)
2015 INTERNATIONAL...
2015 Kubota RTVX1100C (A62177)
2015 Kubota...
2 new 10'' Pallet fork extensions (A61567)
2 new 10'' Pallet...
