Mold in garage/workshop
/ Mold in garage/workshop #1
s219
Super Member
Virginia USA
Kubota L3200, Deere X380, Kubota RTV-X
We moved to a new house next to a coastal river here in tidewater VA, and I finally have the workshop of my dreams -- one bay of a 3-bay garage that is walled off and insulated, with a heat-pump + air conditioner wall unit (called a PTAC unit) for climate control. I generally only fire up the PTAC unit when I am out there working on a project for a length of time, so maybe 1-2 times a week. Otherwise, it stays relatively cool in there because of the insulation, shade from tree cover, the cool concrete floor, and influence of the main house air conditioner on the floors above.
Well, today I went out to work on a project, and noticed small spots of mold everywhere, mostly within 2 feet of floor level. On some walls, on some tools, on lumber, cardboard, etc. I cleaned up what I could, and plan to buy a humidifier tomorrow and spray some mold inhibitor down everywhere. In the meantime, I am letting the PTAC unit run full time (set to 80F) to help dehumidify the workshop, and I left the windows open on the garage bays to ventilate. I moved the cars outside, lest they get attacked by mold.
I double-checked all plumbing for leaks and saw none. I know the garage floor has a thick piece of plastic below the slab which is blocking moisture from the ground. Everything is fairly tight and I didn't find any moisture coming into the garage walls or floor. Based on some reading, it seems like the issue is humidity from the coastal air that gets trapped in the workshop and garage when we open the doors to drive a car in/out or do yard work, and later condenses in the evenings when it cools off. It's been an abnormally rainy and humid summer, which surely isn't helping.
In retrospect, I have been seeing clues for weeks and didn't realize it. I had a pair of sweaty gloves that didn't dry overnight. Another pair of washed gloves got moldy and had to be thrown out. The closet doors in the garage swelled and stick. And a whole bunch of my raw iron tools like pry-bars, hammers, cold chisels, etc have gotten rusty.
Anybody dealt with something like this before and have advice to offer??
thanks,
219
/ Mold in garage/workshop #2
Well all I can tell you is after dealing with the mold left behind after bunch of people decided to abandon flooded houses, best thing you can do is get to ventilating.
Good thing is that it really don't take a whole lot of ventilating at least in your present situation. The bad thing is you need to ventilate probably 6 months of the year because what you got there is a moisture creation system. You're headed along the right road when you say it's humidity coming in during the day and condensing at night.
If you have a peak vent up top you can real easily put a 5" computer fan up there in the vent and run a duct down to the garage floor to pull most of the moisture out, remember you also gotta have makeup air to replace what you pull out, or you go noplace fast.
Far as growing mold you see is concerned, you got a whole lot more you don't see, and if the walls are them big wafer chip board bet you got mold working in there too. That stuff is like a greenhouse for mold.
Get all the goodies out of the garage, get yourself a plastic garden sprayer, and some pool chlorine. Mix up the chlorine in water strong as you can get it, andsprey down everyplace inside the garage. Let it work a couple hours and then ventilate the place till you can't smell the chlorine. After that you can put the toys back in the garage. Regular laundry bleach ain't strong enough to kill mold.
/ Mold in garage/workshop #3
I had mold in my attic and used this Concrobium 1 Gal. Mold Control Fogger, rented from Home Depot and bought a gallon of the chemical. No more mold.
/ Mold in garage/workshop #4
If it's thick wear a respirator mask until you get it under control. Some mold spores can be deadly.
Once you've got mold it's almost impossible to TOTALLY get rid of.
/ Mold in garage/workshop #5
souds like you need ceiling fans to move the air around. this won't get rid of what you already have but will help greatly in keeping new from forming.
My understanding working in the building industry for a while is that mold spores are already everywhere and more spores are always floating around. The first step is to eliminate the conditions in which the spores grow -- moisture, darkness, stagnant air, etc. Then clean up the mold and spores best you can.
I was planning on getting some Concrobium and spraying it around, but if they have a fogger that would be easier for sure, and give me more peace of mind.
So (removed), I was thinking of some sort of ventilation as an alternative to a humidifier. I could leave windows cracked to pull in fresh air on one side of the garage (they are awning style windows, so we can crank them open a little to open the bottom and not worry about rain). How much is enough flow rate to handle a 3-bay garage? It's about 40 feet wide by 23 feet deep, with 12 ft ceilings.
I realize ventilation will just pull in more humid air, so I guess that approach is just keeping it from stagnating, correct?
Any ideas how effective ventilation would be compared to a dehumidifier? I'm looking at a 70 pint per day unit to handle the same space, probably set to maintain 55% RH or so. Would pipe it to the outdoors to drain. Fairly expensive at $270 compared to a small vent fan.
Got a humidifier and plumbed up a temporary drain hose to outside. At 2pm when I fired it up, it was reading 90% humidity in the garage, so I have no doubt we were getting to 100% at night when it cooled down -- I'm lucky it wasn't raining in there. Humidity has slowly dropped to 65% at 9:30pm, after 7.5 hours of running. I have it set to maintain 55%, but will see how feasible that is once we get down to that range (60-65% is probably fine -- I read that mold is curtailed below 68%, but you need some extra margin to account for error in the humidistats).
I also picked up some ceiling fans and am in the process of installing them -- need to run a conduit for power and tie into the garage door opener outlets on the ceiling, and get some longer down rods.
Between the humidifier and the fans, I hope that keeps the humidity at bay and helps dry out any moisture remaining in building materials and the slab.
My Home Depot does rent the fogger for Concrobium, and I plan to get it one day this week and run it while I can keep everyone out of the area. Looks like a great solution to bomb a roomful of mold without having to tear the place apart.
/ Mold in garage/workshop #8
Glad to read you got a DEhumidifier. I've one house in Fulton, Mississippi we only use for storage. We tried keeping it just heated and cooled (between 60 degrees and 82) but it got so humid in there we had to put a dehumidifier in. Made the difference between a sauna and a decent storage place. WELL worth the $$ outlay.
/ Mold in garage/workshop #9
Tell you what, you listen to the radio you hear ads for this wondermachine called THE WAVE they claim is better than anything including the refrigerated dehumidifiers you see all along the curb cause people ain't smart enough to clean the cat hair out of. They even got a website Wave Home Solutions | Basement Dehumidifiers | Basement Ventilation.
Oh I tell you this here machine of theirs will dang sure make you WAVE byeby to your bank account, and if you run it about 1100 years will save you energy dollars enough to pay for it.
Thing is, if you go to their website and look at the Super Machine you can figure out it's an electric switch, and a small fan unit along with some duct work. It ain't nothing a man with about a dollar worth of talent can't make for himself for less than 50 bucks.
I got a fellow I know has been running 3 of the dehumidifiers in his cellar for 4 years, and his wife was madder than a wet hen over the electric bill cause every one of them is like running an ice box in the kitchen when it comes to electric. We got hold of a small blower that came from a high efficiency furnace headed tothe scrapyard, the one that makes the smoke leave the house and put that in his cellar with some 4" pipe going out through the wall. The blower is hanging down so it's just above the cellar floor, cause that's where the air is wettest.
Turned all them dehumidifiers off and just ran that blower 24 hours a day and watched the cellar humidity drop on this little 5 dollar meter from eBay. That blower uses 1/10 horsepower which is a whole lot less than the dehumidifier uses and does 3 or 4 times the work.
Far as how much incoming air you need, as many cubic feet a minute as you're blowing out! You can easy move that through a drier vent on the other side of the room. Chances are you already got enough air leaking into the garage anyhow, but if you don't open a window an inch or so.
When we was dewatering them flooded houses we had fans my nephew makes up from the condenser fan he gets from AC units headed to the scrapper and mounts inside a barrel that's been cut down. You put one of them in a window with some plywood to hold it there, and have it suck air out the house, and open the windows on other side the house and let her go to working. Tell you what, if you ain't got enough windows open you don't want to be trying to open a door with one of them fans sucking. You move air through a room it picks up moisture and hauls it out.
I talked to the HVAC tech in my building at work this morning, and he said unless we have a liquid moisture source causing problems (leak, slab, foundation, etc), ventilation would be of marginal help in this situation, since we'd be pulling in outdoor air that's starting at 80-90% relative humidity this time of year. He said the outside humidity would have to be a good bit lower than the inside humidity for ventilation to be a primary solution in this case. I can see the reasoning there, though I'd love to run through some thermodynamic equations to get hard numbers before ruling out ventilation.
He thought that once the humidifier dried out the air, the ceiling fans would be enough to keep air moving and the humidifier wouldn't have to run very much until we opened a door and cycled more humid air in to the space. I'm not thrilled about having to run fans or dehumidifiers, but I'd rather the bulk of the running be fans if possible.
I think about the garage at our old house and the barn at our old house that never had mold problems, but they were uninsulated and not very tight, so there weren't issues with the interior cooling down at night (they always stayed hotter than outdoors in the evenings). On top of that, the doors were open a lot more often, as that was the only way the spaces were tolerable. Part of me thinks the old way was better, but it was also too hot to work comfortably in those spaces most of the time. Maybe there is no perfect solution....
/ Mold in garage/workshop #12
Don't exaggerate the risk of mold to health. There are certain circumstances where it can be a real problem (immunocompromised due to cancer therapy etc or severely allergic with asthma for example) but for the vast majority of people it is just an everyday exposure to the environment. You will be exposed to more mold spores while gardening or cutting the grass than in your "moldy" garage.
As others point out, the practical solution is to clean it (chlorox) and then keep the area well ventilated and hopefully dehumidified. Tough in Tidewater during the summer.
Why dont you just run the PTAC?
The setup is basically a three-bay garage with the end bay walled off to be the workshop (about 340 sq ft). That's where the PTAC unit is, and it is running in there full time right now and dripping plenty of moisture to the outside drain.
The humidifier is running on the other side of the wall, in the two-bay area where we park the cars.
There is a 32" door on the wall separating the workshop and garage, which I can leave open to trade air. I know the PTAC unit wouldn't be able to cool or dehumidify both spaces though, since it was sized just for the workshop. So I am keeping the door closed for now.
What I may do long term, instead of running the PTAC full time in the workshop, is to either get another small dehumidifier for the workshop area, or see if the existing dehumidifier can handle the entire garage+workshop with that door open. Then, I can simply run the PTAC for heating/cooling only when I am working in the shop, as I had planned.
/ Mold in garage/workshop #14
I wouldn't buy additional equipment unless necessary. Slide the PTAC out and set it on the bench and you have a dehumidifier. You might as well run it and get your cooling out of it. Might just condition the entire space.
/ Mold in garage/workshop #15
I'll say what I'm getting at differently. I would go with a more permanent solution to the problem. Cheap builders model AC to keep the whole thing conditioned.
I was thinking about that, but it would probably be a real waste to air condition the entire garage 24/7 just to deal with a humidity issue. But I will see how things progress over the next few days with the dehumidifier.
/ Mold in garage/workshop #17
Well now I'd dang sure rely on any information a fellow working as a HVAC technician gave me, after all he probably has a degree in HVAC and ain't smart enough to think outside of that degree that should have been left on the dang thermometer.
He's probably way too smart to know you built yourself an airtight chamber right there on top of wet land that comes dang close to being a lifeboat still in operation or using a piece of poly to suck water out of desert sand. That flippin garage sucks water in all day cause it's airtight! Ever since this country went energy nuts people been building air tight chambers to suck water out of the ground under them and paying millions more in energy dollars to get rid of the water they sucked.
I don't care what some college educated fellow claims, moving air picks up water. That's why Mother Nature sends wind behind a rainstorm to pick her water back up that didn't go into the ground.
/ Mold in garage/workshop #18
With a dehumidifier you are cooling then heating the air. At least with an AC unit you can cool the space and reject the heat outside.
/ Mold in garage/workshop #19
Mostly correct. Fresh air intake and exhaust would probably work. Your humidity outside will be different than inside. You can have your garage door open and the humidity will still be different standing inside vs outside.
You can get looser-fresh air ventilation, but the air can only carry so much moisture. You know... Why when it's humid it feels hotter, swamp coolers and cooling towers fall behind.
Or you can get tighter- keep it sealed and go with more permanent equipment.
/ Mold in garage/workshop #20
Air Conditioning does not necessarily mean you are going to remove moisture, and in some instances, AC can actually add moisture to the environment.
Talk to a HVAC professional about installing a whole house dehumidifier. Depending on where your HVAC system is located at, you can tie in the dehumidifier to treat your living area as well as run a bypass system to treat the garage area on it it's own.
Guys in NC use them as dedicated stand alone units for crawl space issues as well as for mold and they do great jobs for that purpose alone.
These are expensive units with their own compressor/coil and drain, but they're dedicated for removing moisture from the air, not lowering the temperature.
I have one in my house (whole house dehumidifier). Outdoor temperture can be running 90 degrees with 85% RH and my indoor temperature never goes below 78, but it feels like it's 72 running at 39% RH inside. First time I noticed that my indoor temperature can be running hotter than the oustide temperature but it still feels cooler. My wife loves it to boot:D
If you want to look at bringing fresh air into a residential structure and moisture is a concearn, you want to look at a energy recovery ventalation unit. Ultimately if outdoor temp and humidity is an issue and you want to bring that air inside, you need to treat the outside air before bringing it into a structure, and that's what a ERV does. The whole house dehumidifier however doesn't have to bring in oustide air, and as mentioned, you can run it as a stand alone unit not needing to tie it into your existing ductwork.
Zato Hydraulic Demolition Shears Excavator Attachment (A61567)
Zato Hydraulic...
TAG 32in. Bucket Excavator Attachment (A60352)
TAG 32in. Bucket...
2006 JLG 2630ES ELECTRIC SCISSOR LIFT (A62129)
2006 JLG 2630ES...
New/Unused Mini Skid Steer Mounting Plate (A61166)
New/Unused Mini...
2014 Ford Explorer AWD SUV (A61569)
2014 Ford Explorer...
2009 Genie TZ-50 50ft Towable Articulated Boom Lift (A61567)
2009 Genie TZ-50...
